Corvette FPR Filter Connection. Will This Work? (Pic Inside)
Oh, and it doesn't show it in this pic, but this setup clears the coil packs on the valvecovers too.
Thanks in advance for any help or suggestions with this.
Mike
The Vette FPR has three port/tubes..the input and return are on one side and with the ouplet by itself.. so. I guess in theory and technically, YES it should work providing you are connecting the correct feel, return, output ports and that the F-Body OEM disconnect connector will seal (I beleive they should).
But will it work with how your configuring it.. I guess it shouldn't be a probelm, but let us know what you find out once you start it up.
As far as teh ground strap, I have nerver read anything about the ground strap really being needed, but if its there.. I would use it. Just ground it to a good Body or Chassis location.
Again, this is a semi-temporary solution. I ordered some fuel fittings and they were not the correct ones, so none of the fittings are gonna work. I'm getting close to starting the car and don't want to wait to order the new fittings. Besides, it'll give me something to work on this winter lol....
Mike
Do away with using the return line from the fuel rail to the tank return port/tube.
Cut the feed line near the tank. Insert the FPR and just run the return back into the tank. This will shorten the Return line and only required the one feed from the tank to the FRP and then to the Fuel Rail.
(Beginning devil's advocate/"nervous Nellie" mode) I definitely wouldn't want to run it that way for any real length of time, just on the off-chance that a leak developed - at around 61 psi, a fuel leak right over the headers there has the potential to be really ugly REALLY quickly...
Guess I'm saying that it should work, but it's def. not optimal.
Just my 2c, good luck.
