Syclone LQ4/4L80E tc78 build
Old 11-14-2008, 11:41 AM
  #41
mjdwyer23's Avatar
Awesome project!
Old 11-14-2008, 11:42 AM
  #42
eviltwin_1987's Avatar
im going to relocated the battery and it will be in that area. kinda like the stock location but more towards the corner of the engine bay. then i will run the dp under the heaterbox and down between the frame and motor. I dont know how big of dp i will be able to fit but i want atleast a 3.5" but im not afraid to do some cutting and welding on the truck
Old 11-15-2008, 02:04 AM
  #43
well got alot done today. pulled the front end all part. got everything ready to pull the tranny and then the motor tomorrow. pulled the t-case, turbo, upper intake, and everything that mounts to the fenders. took out the a/c and abs. 9 bolts on the trans and 2 bolts on the motor and everything will be out.
i love driving a good running truck into the driveway just to rip it apart
Old 11-15-2008, 04:43 PM
  #44
update
now its time to
Old 11-15-2008, 04:53 PM
  #45
the_merv's Avatar
That thing's going to go like a Rocket..hopefully the Drive Train holds up to that..
Old 11-15-2008, 07:21 PM
  #46
extremetoy's Avatar
wooooaaaa theres a monster truck in the background
Old 11-15-2008, 07:40 PM
  #47
a 2wd monster truck
Old 11-15-2008, 09:19 PM
  #48
Summerwolf's Avatar
You suck at life. Syclone should only be AWD 4.3 turbo.
Old 11-15-2008, 09:20 PM
  #49
squee's Avatar
Kinda harsh, but I kinda agree.
The only reason I would do something like this is if it wasn't the original motor, no motor at all, etc.
Old 11-15-2008, 09:29 PM
  #50
Not this one! 4.3 is over rated and this will be faster, more reliable, and probably better mpg's.
Old 11-15-2008, 09:34 PM
  #51
pist0lpete's Avatar
There will always be nay-sayers I think its a cool swap. Anything that increases the power and reliability makes sense in my mind. Its not like your tearing up a COPO camaro or something they did make a few more than 69 of those SY/TY's.
Old 11-15-2008, 09:36 PM
  #52
squee's Avatar
Typhoons are infact more common, but they only made something like 2995 Syclones. I've only seen 3 I think total. 1 of which is sitting in my driveway.
Old 11-15-2008, 10:25 PM
  #53
the_merv's Avatar
How the **** you going to bash on a mans project?
Seriously, out of nowhere..
That thing when complete will smoke that fat *** GTSLO..without a ******* problem..
Basically
Old 11-15-2008, 10:36 PM
  #54
trailwart's Avatar
nice swap. ive seen some videos in the past of an lsx syclone, it was bad ***. they were on streetfire or youtube. 100ft. 4 wheel burnouts were no problem.
Old 11-16-2008, 02:46 AM
  #55
Basically
got the fuel pump in. will go in the truck tomorrow.
Old 11-16-2008, 06:07 AM
  #56
Summerwolf's Avatar
Basically
Never said anything about my car or how fast it is/isn't or anything. Its just with less than 3000 Syclones made, and them being a one year only vehicle they were unique as hell to begin with. That one was he said "nice running" and it looks clean as sin....why take a collectors item and molest it?
If it was a blown motor- understandable, way to go. But in my mind there a MILLION and one GMC S15 or Chevy S10 on the road, and they're cheap as hell to buy, there were only so many true, numbered, syclones for sale and IMO they should be kept stock to mostly stock.
Old 11-16-2008, 09:05 AM
  #57
jfg455's Avatar
I say cut it up! it only makes all the other ones more valuable! God I hate the "but it's not stock any more" haters. That thing is going to be cool! Keep it up. Let me know if you need any help with GM wiring diagrams. I'm a GM tech. G
Old 11-16-2008, 09:26 AM
  #58
sparkwirez06's Avatar
Originally Posted by eviltwin_1987
just waiting on some oil line fittings
ready to pull the motor/trans this weekend?
broke my wrist in march. i went over the bars on my mountain bike and landed on my arm. i was on the smallest jump ever.
worked on the pan some more
That pan looks a little familliar http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/asl http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/anw
http://www.turbols6.com/gallery/TYPHOON-LSX-TURBO/any
I made a very same pan!! It only holds 4.5 qts. of oil I decided to up grade the pan to six qts. with a remote filter and oil cooler, after I read this, https://ls1tech.com/forums/forced-in...tarvation.html I might go bigger on the lines!!
Check into the hydroboost brakes, fairly cheap mod. will give you a lot more room for your coils ect!! Good luck with the build, I've had mine done a couple of times, keep changing my mind, and the WHILE I'M In HERE, bug keeps bitting me. It also put's a big dent in your budget!! LOL
Old 11-16-2008, 09:45 AM
  #59
lightning95sc's Avatar
Everyone has their opinion, and I'm not knocking yours. But why do you think the OEM's move on to other things? Technology gets better. If it can be retrofitted and make a vehicle better, safer, and faster, why not do it.
As I stated above, I'm not knocking your opinion....Why should you rag this guy for building a cool, and better project? JUST MY OPINION!!!
Chuck
Old 11-16-2008, 11:38 AM
  #60
mjdwyer23's Avatar
Chuck
+1! Better, faster, stronger.
Quick Reply: Syclone LQ4/4L80E tc78 build
