mustang suspension question
I wouldn't.... you can just run the factory 4cyl uppers and lowers or just buy yourself from uppers and lowers. I wouldn't run the sn95 uppers and lowers as they are a tad bit longer than the fox body ones.
i already have cobra rear with cobra brakes so the gt ones are outta the question... but my question is what axles do i need to get to get back to stock track with that will work with the cobra brake bracket. i know i can use ranger axles but i want to get some 31 spline axles and tru trac in the future
LES SS
i think it was your thread were i saw you using a 4cyl drive shaft for the swap ?? what yoke and u-joint did you end up using if it was you??
could of been someone else ive been reading them all a million times to make sure i get all the info and parts i need
thanks jorge
sorry if i keep asking all these questions
thanks jorge
im assuming you were talkin about those clutch line fitting...
if not it just some -6an male hard line fittings and some -6an female fittings. and i bought 20ft of -6 braided hose. so you will need 4 of each... for the hard line fitting right off of the tank you will need a 5/16 male hard line fitting. the other 3 hard line fittings are 3/8.
1 5/16 -6an hard line fiting
3 3/8 -6an hard line fittings
4 -6an female fittings
LES SS
thanks jorge
thanks jorge
i made a list of all the things iam going to need from russell is there anything im missing ?
- clutch master cylinder fitting
- slave cylinder fitting
- clutch line and fitting for both ends
- power steering fittings
- fuel filter fittings for filter and line
- fitting for injecter rail and line
- gas line return and feed
- fittings for gas line
#38
on the wiring hardness you left the 4cyl inside hardness for lights radio etc
what does speartech do to the ls1 hardness to make it work into the 4cyl mustang hardness????
