mustang suspension question
Old Nov 17, 2008 | 04:19 PM
wheelies247's Avatar
Default mustang suspension question
i have a 4cyl mustang to do my swap
the rear end in it is a 7.5 so am looking at a sn95 ( 94-98) rear w/ disc brakes
whats the different between the 87-93 8.8 rear and 94-98 rear cobra or gt besides the drum brakes ????? i could do a disc brake swap on the 87-93 8.8??
and if i do this swap do i have to use the sn95 or fox body rear upper & lower control arms and shock ?????
will the aje ls1 k-member fit on the 4cyl ???
i also have the chance to get the sn95 front spindle and cailper, rotors. does it matter if it a gt or cobra. do i need to use the shock & lower control arm from the sn95 on the mustang and does the lower control arm fit in to the aje k member
Old Nov 17, 2008 | 05:55 PM
forgotten's Avatar
I believe the sn-95 rear end is 3/4 " wider than the fox body rear end. I am planning on doing this exact same thing so be sure to list your swap and your discoveries. Mustang forums might have more info on this stuff.
Old Nov 18, 2008 | 05:54 AM
mg98ta's Avatar
The sn95 rear is wider. I think there is a swap kit out there to use the sn95 disc brakes on the 87-93 rear. The upper and lower control arms are the same.
Yes, the AJE LS1 k member will fit the 4 cyl. car. The frame mounting positions are the same on 4,6, & 8 cyl. Mustangs.
Check out www.Corral.net for the disc brake swap.
I have a friend that done the exact disc brake swap. I'll email him and find out what he had to use. Hope this helps.
Old Nov 18, 2008 | 10:00 AM
so i can use the sn95 upper and lower control arms and shocks on the 4cyl mustang???
Old Nov 18, 2008 | 10:35 AM
Mclovin95's Avatar
you should be able to use the same shocks and uppers and lowers and if your putting an sn95 rear in it you'll have 5 lug on the back and 4 lug on the front. if you do that you can use gt 5 lug spindles and gt brakes and lincoln mark 8 rotors and youll have 5 lug all around
Old Nov 18, 2008 | 11:21 AM
mg98ta's Avatar
All the uppers and lowers are the same and have the same mounting locations. The shocks also have the same mounting positions. Length of the shocks i'm not sure about. They should be the same though.
Old Nov 18, 2008 | 12:05 PM
Les_SS's Avatar
i have a 4cyl conversion with everything your talkin about.. if you look under my built thread i have plenty of pics! aje k member, cobra brakes and cobra rear..
Old Nov 18, 2008 | 12:25 PM
SOM68SS's Avatar
North Race Cars makes a custom mounting bracker to use the SN-95 Disk brakes on the Stock Fow Length axles.
These are for Cobra brakes
http://www.latemodelrestoration.com/...0%201&comp=LRS
These are for GT Brakes
Old Nov 18, 2008 | 05:18 PM
Les_SS's Avatar
i was planning on getting these since my wheels are out too far with the 10.5's on the back... do i need to run the ranger axles with this or what?
Old Nov 18, 2008 | 08:16 PM
LES SS your car looks fu*cking sweet with the 10.5 wheels out like that. fits with the fender real nice
what size tires are you running on the front and back? 4cyl springs all the way around???
if you launch the car to hard will it hit the fenders in the rear ??????
Old Nov 18, 2008 | 08:20 PM
SOM68SS
would i have to change the master or booster with disc brakes all around or could i just run the 4cyl set up
LES SS
do you stay with the 4cyl set up??
Old Nov 18, 2008 | 08:22 PM
LES SS
on your swap did you use the sn95 rear upper and lower control arms or the 4cyl ???
on the front would i use the sn95 or 4cyl lower control arm ????
Old Nov 18, 2008 | 08:28 PM
Coreyc619's Avatar
you have to change the master cylinder to a 93 cobra for the discs.. and add a proportioning valve.. usually a good spot is the PS firewall. or thats one of the easier routes to go..
dont think of using the PS rangers axles theyre weak as sh*t. GT brakes would be much easier to fit a 15" skinny drag style wheel up front.. just buy some decent axles.
if your gonna do a drag setup id recommend using c-clip eliminators
Old Nov 18, 2008 | 08:53 PM
weres a good place to start looking for the proportioning valve
regulate front and rear pressure ??
Old Nov 19, 2008 | 05:47 AM
mg98ta's Avatar
Like I say, check out www.Corral.net. Or try an ebay search. Either should bring up some parts for ya. Good luck on ur swap. Keep us posted.
Old Nov 19, 2008 | 09:42 AM
what does the proportioning valve really do and how would it help with my braking is it an adjustable valve ????
Old Nov 19, 2008 | 11:08 AM
mg98ta's Avatar
Yes, it's an adjustable valve that adjust the pressure between the front and rear brakes. Too much pressure to the back brakes causes the back brakes to lock up sooner than the fronts. Hope this helps.
Old Nov 19, 2008 | 12:22 PM
SOM68SS's Avatar
Originally Posted by wheelies247
SOM68SS
LES SS
You will use the same length axles that you have but just five lug
28 spline is factory
Or you can upgrade to 31 apline
You will have to run a master cylinder designed for disk brake applications
1993 Cobra is the easiest but you can modify others to work as well, as far as proportioning valves go..most people I have seen mount a small willwood adjustable valve on the rear line that runs across the top of the firewall. They just replace the connector with the valve.
Old Nov 19, 2008 | 02:15 PM
Les_SS's Avatar
at first i was runnin cut 4cyl springs that had been cut before the swap. but the tires would rub bad in the back.. so i put stock 5.0 springs front and back and the front fender gap was like 8 inches from tire to fender. so i cut 1-3/4 coils off the fron and left the rear 5.0 un touched. its rides pretty good with that setup now too. not bouncy or anything of that nature..
SOM68SS
LES SS
i havent changed my booster or master yet.. you dont have to change it asap to drive the car but to get the best out of the brake swap its good to change them..
LES SS
on the rear i used my stock 4cyl control arms for now, they bolt right up. in the front im using 87-93 aje tubular control arms. but you can use 4cyl ones if you want. its just harder to get the camber settings in spec with 87-93 control arms over the sn95
Old Nov 19, 2008 | 02:18 PM
Les_SS's Avatar
i already have cobra rear with cobra brakes so the gt ones are outta the question... but my question is what axles do i need to get to get back to stock track with that will work with the cobra brake bracket. i know i can use ranger axles but i want to get some 31 spline axles and tru trac in the future
