Pre bent fuel lines?
Old Nov 18, 2008 | 05:29 PM
samh_08's Avatar
Default Pre bent fuel lines?
I there such a thing as pre bent fuel lines. It would need to work in a 86 monte carlo for a return style system. If there is such a product, where would I find it?
Thanks guys,
Sam
Old Nov 18, 2008 | 05:53 PM
bczee's Avatar
If your asking for Pre-Bent fuel line from the LSx fuel rail to your 86 monte.. I don't think so.. most people just fab and bend up what they need. You can get Pre-Bent lines for the rest of the car.. like from tank to the front, but you are on your own to get it from there to the fuel rail and return line.
Old Nov 18, 2008 | 07:30 PM
samh_08's Avatar
Thats totally fine. I just need the ones that run the length of the car. I should be able to fab up the rest of it no prob. And idea on where I can find these?
Old Nov 18, 2008 | 08:14 PM
deuce4935's Avatar
http://www.inlinetube.com/
Old Nov 18, 2008 | 08:27 PM
samh_08's Avatar
Originally Posted by deuce4935
Exactly what I needed, thanks. Now do I need all 3 of these, or just the top 2?
Fuel Lines (V8 Fuel Injected)
CMF8109 Main Fuel Line 3/8" 2pc F.I. $110.00
CMF8110 Fuel Return Line 5/16" 1pc F.I. $105.00
CMF8111 Frame / Tank Return Line 5/16" 1pc$30.00
Old Nov 18, 2008 | 09:54 PM
ryanvv355's Avatar
If i could make a suggestion; Summit sells 25ft coils of aluminum 3/8" fuel line for $19. This stuff can be manipulated by hand and is very workable. To flare to 37* AN you can get the flare tool from them for $30. Tube nuts and sleeves are $2 a pair. The 37* flare will allow you to connect the tube nut directly to an AN fitting. This may be a cheaper route plus you will get a tool out of it.
Also you should have a segment of soft line between the frame/body and engine to account for engine movement
Old Nov 19, 2008 | 01:34 AM
bczee's Avatar
I got mine from ClassicTube.com, they are about the same products as inlinetube.com
I also did my brake lines while I was at it.
Old Nov 19, 2008 | 07:32 AM
samh_08's Avatar
How was their product? Details man
Old Nov 19, 2008 | 08:37 AM
A_VAS's Avatar
I've ordered pre-bent stainless brake lines from these guys, and was very happy with the fit and quality.
http://www.rightstuffdetailing.com/2...onte_carlo.pdf
