TRANSMISSION COOLER 4l60
I did have to trim my filler panel a little bit, but it'll clean up well.
https://ls1tech.com/forums/conversio...version-6.html
My Duramax 2500 with an Allisson transmission doesnt use the radiator. My transmission cooler runs 5/8" line and its the size of my radiator. Granted this is a different transmission and tows 20,000lb+
http://trucool.carshopinc.com/index....rers_id/373538
This would be the best setup
And if not the next best would be this which you can buy at autozone for around $35
http://www.derale.com/pans.html
I am not running fluid through the radiator. I am running a 2800 stall Yank convertor and so far so good, been on the road for 2 years and 9,000 miles.
Pat
Pat
no problem running that one. is it on the side of the car too? i bet the pan helps out alot too. do you have a gauge on it?
