What is "limp mode"?
P0740: Torque Converter Clutch (TCC) enable solenoid control circuit
P0753: 1-2 shift solenoid control circuit
P0785: Shift Timing Solenoid
P1860: Torque Converter Clutch (TCC) PWM solenoid control Circuit
Engine revs fine when in park/nuetral, she does seem to stumble a bit at idle, but when I put it in gear, any, forward or reverse and give it gas, it falls on its face and won't even move. Is that limp mode? Done the search but can't find a good defination of it.
I'm going to recheck all my wires and connections later this week. Have 12V power to Harness E wire. The harness is not original, repalcement that I had to wire in since the harness I had was for a stick car.
My first reaction to the codes is that the connector on the trans(big round one) is not seated properly, or you have some bent/pushed pins on that connector. I would start there.
Jack
So the car will still drive? I'm not even getting that. It is just starving when its in gear.
Well, thought I was good. Got my steering joint/shaft in and went to roll the II out. Backs up fine, reverse is good. Go to go forward and ****, nothing much. 2nd and 3rd, car will move, bam, code pops back up. P0758, A solehoid, 2-3 shift. ****, now I gotta figure out why.
Maybe a solenoid needs replacing? Everything seems to be wired up right, powered and connectors are good.
