Lq4 pcm pinout
Old Jan 13, 2009 | 07:44 PM
Old Geezer's Avatar
Question Lq4 pcm pinout
Been searching for a couple hrs, and have found zip.
I have a 2005 Hummer H2 6.0, and need to eliminate the uneeded wiring. [PCM service # is 12589463]
NE1 have a pinout, or other info that I may use??
If you have th einfo, I'd appreciate an email, or a place to find such.. codymspt@bellsouth.net
THANKS!
Old Jan 13, 2009 | 09:23 PM
Bo185's Avatar
THANKS!
These should be close.
https://ls1tech.com/forums/7751990-post71.html
Old Jan 14, 2009 | 07:04 AM
HDon22s's Avatar
Check w/ poconojoe seems very helpful w/details
Old Jan 14, 2009 | 09:52 AM
Old Geezer's Avatar
Thumbs up Thanks..
for the help!
I'll check w/ Joe, to see if he has NE more info...
Getting there, slow, but sure!!
Old Jan 14, 2009 | 11:16 AM
lt4malibu's Avatar
Connector #1
Connector Part Information
• 12191489
• 80-Way F Micro-Pack 100 W Sealed (BU)
Pin
Wire Color
Circuit No.
Function
1
BK/WH
451
Ground
2
L-GN
1867
12-Volt Reference
3
PK/BK
1746
Fuel Injector 3 Control
4
L-GN/BK
1745
Fuel Injector 2 Control
5-6
Not Used
7
GY
2705
5-Volt Reference
8-10
Not Used
11
L-BU
1876
Knock Sensor 2 Signal
12
D-BU/WH
1869
CKP Sensor Signal
13
Not Used
14
OG/BK
1061
UART Serial Data
15
D-BU/WH
774
UART Serial Data
16
Not Used
17
D-BU
1225
Transmission Fluid Pressure Switch Signal B
18
RD
1226
Transmission Fluid Pressure Switch Signal C
19
PK
439
Ignition 1 Voltage
20
OG
440
Battery Positive Voltage
21
YE/BK
1868
Low Reference
22
Not Used
23
BK
470
Low Reference
24
BK/WH
451
Ground
25
TN
1671
HO2S Low Signal - Bank 2 Sensor 2
26
TN
1667
HO2S Low Signal - Bank 2 Sensor 1
27
BK/WH
451
Ground
28
TN/WH
1669
HO2S Low Signal - Bank 1 Sensor 2
29
TN
1664
HO2S Low Signal - Bank 1 Sensor 1
30-31
Not Used
32
BK/WH
771
Transmission Range Switch Signal A
33
PU
420
TCC Brake Switch Signal
34
WH
776
Transmission Range Switch Signal P
35
Not Used
36
BK
1744
Fuel Injector 1 Control
37
YE/BK
846
Fuel Injector 6 Control
38
Not Used
39
YE/BK
625
Starter Enable Relay Control
40
BK/WH
451
Ground
41-42
Not Used
43
RD/BK
877
Fuel Injector 7 Control
44
L-BU/BK
844
Fuel Injector 4 Control
45
GY
2700
5-Volt Reference
46
GY
474
5-Volt Reference
47
Not Used
48
GY
597
5-Volt Reference
49-50
Not Used
51
D-BU
496
Knock Sensor 1 Signal
52
Not Used
53
BK
407
Low Reference
54
OG/BK
469
Low Reference
55-56
Not Used
57
OG
440
58
D-GN
1049
Class 2 Serial Data
59
YE
710
Class 2 Serial Data
60
Not Used
61
PK/BK
632
Low Reference
62
Not Used
63
BK
2755
Low Reference
64
BK/WH
451
Ground
65
PU
1670
HO2S High Signal - Bank 2 Sensor 2
66
PU
1666
HO2S High Signal - Bank 2 Sensor 1
67
BK/WH
451
Ground
68
PU/WH
1668
HO2S High Signal - Bank 1 Sensor 2
69
PU/WH
1665
HO2S High Signal - Bank 1 Sensor 1
70
BN
1174
Oil Level Switch Signal
71
Not Used
72
YE
772
Transmission Range Switch Signal B
73
BN/WH
633
CMP Sensor Signal
74
YE
410
ECT Sensor Signal
75
PK
1020
Ignition 0 Voltage
76
BK/WH
845
Fuel Injector 5 Control
77
D-BU/WH
878
Fuel Injector 8 Control
78
Not Used
79
WH
687
3-2 Shift Solenoid Valve Control
80
GY
720
Low Reference
Connector #2
• 12191488
• 80-Way F Micro-Pack 100 W Sealed (GN)
Pin
Wire Color
Circuit No.
Function
1
BK/WH
451
Ground
2
BN
418
TCC PWM Solenoid Valve Control
3-5
Not Used
6
RD/BK
1228
PC Solenoid Valve High Control (Sol. A)
7
Not Used
8
L-BU/WH
1229
PC Solenoid Valve Low Control (Sol. A)
9
D-GN/WH
465
Fuel Pump Relay Control
10
WH
121
Engine Speed Signal
11-13
Not Used
14
RD/BK
380
A/C Refrigerant Pressure Sensor Signal
15
BN
25
Charge Indicator Control
16
GY/BK
1694
4WD Low Signal
17-19
Not Used
20
L-GN/BK
822
VSS Low Signal
21
PU/WH
821
VSS High Signal
22-24
Not Used
25
TN
472
IAT Sensor Signal
26
PU
2121
IC 1 Control
27
RD
2127
IC 7 Control
28
L-BU/WH
2126
IC 6 Control
29
D-GN/WH
2124
IC 4 Control
30
Not Used
31
YE
492
MAF Sensor Signal
32
L-GN
432
MAP Sensor Signal
33
Not Used
34
D-GN/WH
428
EVAP Canister Purge Solenoid Control
35-38
Not Used
39
RD
631
12-Volt Reference
40
BK/WH
451
Ground
41
Not Used
42
TN/BK
422
TCC Solenoid Valve Control
43
D-GN/WH
459
A/C Compressor Clutch Relay Control
44
Not Used
45
WH
1310
EVAP Canister Vent Solenoid Control
46
BN/WH
419
MIL Control
47
YE/BK
1223
Shift Solenoid B Valve Control
48
L-GN
1222
Shift Solenoid A Valve Control
49
Not Used
50
D-GN/WH
817
Vehicle Speed Signal
51
YE/BK
1227
TFT Sensor Signal
52
BN
2391
HO2S Heater Low Control - Bank 1 Sensor 2
53
RD/WH
3223
HO2S Heater Low Control - Bank 2 Sensor 2
54
PU/WH
1589
Fuel Level Sensor Signal
55-56
Not Used
57
BK
552
Low Reference
58
TN/WH
332
Oil Pressure Sensor Signal
59
PU
806
Crank Voltage
60
BN
2129
Low Reference
61
BN/WH
2130
Low Reference
62
GY
773
Transmission Range Switch Signal C
63
PK
1224
Transmission Fluid Pressure Switch Signal A
64
D-GN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PU/WH
2128
IC 8 Control
67
RD/WH
2122
IC 2 Control
68
D-GN
2125
IC 5 Control
69
L-BU
2123
IC 3 Control
70-71
Not Used
72
BK/WH
3113
HO2S Heater Low Control - Bank 1 Sensor 1
73
Not Used
74
L-GN
3212
HO2S Heater Low Control - Bank 2 Sensor 1
75
GY
23
Generator Field Duty Cycle Signal
76-79
Not Used
80
BK
2751
Low Reference
Old Jan 14, 2009 | 01:42 PM
Old Geezer's Avatar
Thumbs up Wow!!
Thanks a bunch. Got it saved and printed.
Now, all I have to do is "finish up"!!!!!
Old Jan 14, 2009 | 05:36 PM
Old Geezer's Avatar
1 last ?? How does the gray cover plate come off the PCM plug?? [gettin too old, I guess. Logic escapes me!]
Old Jan 14, 2009 | 07:52 PM
poconojoe's Avatar
I take a pair of needlenose pliers and gently grap both sides of the plastic standoffs and twist the pliers slightly as I use leverage off the metal connector housing, to lift it up. Sorry I didn't get in your thread earlier, if you need any prints Email me
