Reservoir to clutch master hose routing ok?
Been dreading cutting the hole in the fire wall on my Chevelle for the master cyl for quite some time now, but I finally did it today! From looking at this picture, do you think that the position of the reservoir, and routing of the hose will be a problem for hydraulic operation?
![](http://i11.photobucket.com/albums/a159/RacnJsn95/ChevelleStuff/2309003.jpg)
Also, does anyone know where/if I can get the fitting that the end of the braided master cyl line fits into? I think it's a quick disconnect, right?
That's what I was curious about... I wasn't sure if it would be a problem or not...
It doesn't seem like the line off the master cylinder would reach to the slave cylinder... I suppose that's what I mean though... Whatever the fitting or attachment the end of the master cylinder line connects to.
I dont think the line from the master cylinder will reach to the slave cylinder, so I was thinking I may have to have another line from the slave cylinder with the fitting on the end to reach the master cylinder line.
I would install your Power Booster to make sure that you have room for it there.. I mounted mine directly behind and higher that the booster because the Brake line (stock) were routed where your planning on mounting yours. But yours maybe routed differently.
As far as the connectors on the line, the master should have on part of the Quick Disconnect the the Slave would already have the other half of the Disconnect.
