86 Elcamino LS1 Swap G body.....which oil pan has best ground clearance????
Need good ground clearance on a 1986 G-Body El Camino, the car is low and I dont want the pan hanging below the crossmember. The LH8 hangs too low, and the street and performance pan only holds 4 quarts of oil....so I wont be going that route! I have heard that the CTS-V pan might work, I know it works great in my chevelle. Anybody have a pan / motor mount combo that fits nicely and gives good ground clearance? Please post it!
The following users liked this post:
Blac94z28 (06-02-2023)
LH8 Pan hangs way below the crossmember, so this is not a option on this car. Car sits very low, oil pan will be in danger of being smacked by debris / speed bumps / etc. I guess ill have to throw my junk LS1 block in there as a mockup and try a couple pans out. Im leaning towards cutting and shortening a truck pan....i can chop 3 inches out of it and still retain 5 quarts of oil. The LH8 pan is only about 1" shallower than the truck pan surprisingly, the way it slopes downward towards the rear and drain plug.
If ground clearance is your absolute #1 concern, I would follow G-Body's advice.
I used a CTS-V pan along with motor mount plates from CarShopInc which keeps the motor pretty low. The pan hangs about 3/4" - 1" below the front crossmember.
If you didnt want to mess with passenger head clearance issues you might be able to use the CTS-V pan with BRP motor mounts which would raise the motor up a bit...probably a good inch or more and that would make the CTS pan clear just fine and allow the motor to be placed forward enough for great A/C box clearance.
The cts-v pan is the perfect choice for this install. Heres a link to one already in use:
http://www.maliburacing.com/forum/vi...p?f=29&t=73834
Damn man almost had it u just had to say "What is" before your answer haha, but yea that's what I meant lmao mybad
I first used the GMPP pan, but it hung too low, so I switched to the Holley 302-2. Here's a thread about it: https://ls1tech.com/forums/conversio...r-oil-pan.html
gbodychango69 (09-29-2022)
