Need help with engine serial number
Old Feb 27, 2009 | 04:29 PM
barnat's Avatar
Default Need help with engine serial number
Hey guys, I bought an older engine for a spare for another car project ive got going and the guy said its a 350 but im not sureThe numbers on the passanger side deck of the block is v0514tyz
If anybody can help me,, it will be appreciated PLEASE PM me if you know anything!Thanks BARNAT
Old Feb 27, 2009 | 05:44 PM
barnat's Avatar
DO ANY OF YOU KNOW WHERE I MIGHT LOOK THAT DOESNT COST MONEY ?lol
ITS GOT THE MSD DIDTRIBUTER WITH THE POINTS INSIDE!My buddy said it actually may be a numbers matching 327 or a 307 which if it is ,i might sell instead of rebuilding .I know alot of guys with older camaros or classic cars with nonmatched engines would love to have this !im guessing!
Old Feb 27, 2009 | 07:20 PM
barnat's Avatar
the casting # says 397000!
Old Feb 27, 2009 | 07:29 PM
Shawn MacAnanny's Avatar
I wouldnt imagine a 350, 327 or 305 would be of much value... Just type all the numbers you find into the Google search engine. You're bound to find info on it. Just using the block number doesnt mean thats the engine displacement. It could be bored, stroked, destroked.
Old Feb 27, 2009 | 08:09 PM
67rsss's Avatar
Number on the pass pad won't help you, The block number is used too widely to get you there from here, though I think you meant 3970010. We will need more info to identify the engine. You will most likely be pulling a head and making a few measurements... If you can measure the bore and the stroke, you can identify the engine. Drop the pan, and you will also identify the main caps (2 or 4 bolt).
cid - bore - stroke
283 - 3.750 - 3.000
302 - 4.000 - 3.000
305 - 3.736 - 3.480
307 - 3.875 - 3.250
327 - 4.000 - 3.250
350 - 4.000 - 3.480
Don't forget that it is not uncommon for engines to have larger bores in .010, .020, .030, .040, and .060 inches.
Pray for a 4.00 x 3.00, 302's have good resale value!
Old Feb 27, 2009 | 08:27 PM
LS1MCSS's Avatar
Suffix code tyz is a 1975 350, 165hp.
Old Feb 27, 2009 | 09:00 PM
67rsss's Avatar
Wow, missed the suffix completely!
Old Feb 27, 2009 | 09:47 PM
V8Rumble's Avatar
1st, using all capital letters is generally considered to be poor etiquette, most of the time it's seen as "shouting".
Next, this link may prove helpful - Mortec.com
Good luck!
Old Feb 27, 2009 | 10:01 PM
barnat's Avatar
The cast # is 397000!! but after i did a search it looks like my # is a few short and i dont understand this !If 10 were added to this number it would be a 302 engine from what ive seen on the search .Any help guys
Old Feb 27, 2009 | 10:18 PM
Stu Cool's Avatar
LS1MCSS just gave you the answer....
Old Feb 27, 2009 | 10:48 PM
barnat's Avatar
Yea, but why cant i find the cast number? I did a google search and it looks like i can use this casting number 397000 engine on the monett speedway LOL, but can't pull it up ANYWHERE on all the casting sites ive checked today ? You dont think thats weird!and it is the correct casting number too
