Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Camaro and Firebird: Guide for Budget Engine Swap
Important information to help you understand your Camaro or Firebird
My Budget LS Engine Swap Guide <$1500
#161
what are you dropping it into? the first post has answers to your questions so far, but you'll need a fuel system (depending on swap car), motor mounts (depending on swap car), an accessory drive (depending on where you got your engine & how complete it is/was), transmission from LS vehicle or transmission adapter kit (bolts, flexplate/flywheel spacer, etc), have your ECM flashed to remove unwanted 'components'... if you haven't already, I would read this entire topic
#162
i'm a member of the third gen camero site, and this one is even better. i am just starting a ls swap in my 91 camero. my donor truck was a 2003 1500 4.8. i have already tackled
removing the wiring harness and the engine. would it be worth buying a harness of of this site or just chopping mine. keep in mind that my 4.8,harness,and computer was free.
also am i gonna need to get a car computer or will my donor work?
#163
#164
IT IS A 91 CHEVY CAPRICE WITH 305 TBI. I READ EVERY 5.3 TOPIC ON HERE . I MEAN THE WHOLE THING . I HAVE SOME KNOWLEDGE . SO I NEED THE FUEL SYSTEM FROM THE 03 TAHOE OR SOMETHING ELSE.MOTOR MOUNTS CUSTOM OR CAN I USE SOMETHING FROM ANOTHER CAR FOR A CHEAP SWAP. THE DRIVE IS COMPLETE ALT,HARM BALANCER, WATER,ETC. I HAVE A 700-R4 NOT A 4LOE. I HAVE HAVE LAPTOP HOOK-UP PROGRAMS. SO I CAN TUNE MYSELF. THANKS FOR THE HELP . GOT ANY MORE
#165
#166
Very nice work! I just happened to stumble upon this site the other day and had to register. If I'm understanding your post correclty....I have come across a complete 6.0l vortec including everything from the fan right down to the gas pedal and everything in between(harness, computer intake......everything) and I'm thinking about putting it in my 72 4x4 suburban. How difficult do you think this would be? Thanks in advance, Richard
#167
My father are planning on swapping in either an LS1 or a 5.3L into his CJ7 and my Scout 2. I'm liking the idea of the 5.3L more and more, but I have a couple questions.
Our primary reasons for doing this is to increase our fuel economy, drive-ability/cold starts/ease of use, and power, in that order. I see LS1 equipped cars getting 28mpg+ on the highway, so I'd like to think I should be able to get around 18-20mpg in my 4500lbs. Scout and better in his lighter Jeep. Does this sound attainable to you guys?
We're thinking we'd probably swap on the LS1 intake, rails, and injectors as well. With this setup on the 5.3L, what's a ballpark horsepower and torque figure we could expect?
Thanks for this excellent thread!!
#169
This is a great thread, but the biggest problem I have with it is a lack of explanation on how to find these engines for $350. I paid way more then that, of course, mine came with everything, trans and all. I look on car-part, and even the 150K mile plus motors are at $500 or so. Are you guys putting motors with 150K in your project cars? Mine has 32K. I would love to hear what you paid for your motor, how you found it, and how many miles it had, if you are willing to share (anyone that is, not just the OP).
Thanks,
Orlando
Thanks,
Orlando
#170
I paid $750 for my 5.3L that was everything that touched the motor except the tranny(4x4 so did'nt want it). Thats all wiring, computer, UHFB, all accesories. Motor had 120K on it. Just started it a couple wks ago, sounds good. Inside looked good too. I can get a 5.3L for $450 thats w/o all the wiring, mileage unkown they just pull them out. Come w/ a 1 year warranty. Same place wants $1200 for complete setup.
I'm also curious to see what everyone else is paying.
#171
OK, that somewhat answers my question. Thanks for being honest. Personally I would never put a 120K motor in one of my cars. Part of the reason I went to the newer motor is reliability and mileage, I think with 120K you are asking for breakdowns.
Orlando
Orlando
#173
I wouldn't think twice about swapping in an engine with 120k on it as long as it appears decent. The breakdowns usually come from sensors failing and other issues. I do my swaps with new O2s and MAFS and check all other sensor operation once they are running. These engines don't usually just "fail" with 100k miles on them. As mentioned many, many times they usually still look new inside (cylinder crosshatch, no ridge) due to excellent fuel injection properties. These aren't old small block - carbed engines. My Silverado has 200k on its original engine and trans and runs and drives literally like it is new still.
Also, some of these prices originally written have since changed since I originally made this thread a while back.
#174
OK,
This is all good to know. The one I bought only has 32K on it right now, and if I ever finish the frame/body work (why do these projects always become a frame off when you dump in a nice shiny motor?) I should get years of enjoyment out of it.
Orlando
Orlando
#175
Are there any good sources for an affordable 5.3 in the new york, new jersey area i keep running into the salvage yard shell game they want a lot for a motor because they pulled it or they offer you deal on a motor that they are not sure of the mileage or if it even runs.. looking for two good motors a 5.3 and a 6.0... Any help would be appreciated...
#176
When the same mis-info gets spread
Ok, so everyone references these diagrams, regarding a 1998 to 1999 swap. And to be specific I mean the conversion diagrams. But has anyone noticed that the conversion diagrams for both the 98 and 99 only show connectors C220 and C230?? Now I will admit, I havent read every single response to see if anyone noticed this, but come on guys!
The main diff between the 98/99 is that in 98 they had 3 connectors going thru the firewall. So if your planning to depict a conversion diagram between a 98 & 99 ... why not show C210?
I mean correct me if I'm wrong
#177
Thanks for the thread and all the info.
I have a 73 Formula Firebird with a 350 and need more power!
the cost of 455 builds have me really thinking hard about an LS swap, I wish there was a shop in the NW that had experience doing them.
If you were closer, I'd be writing you a check right now.
#179
I was planning on putting an LS1 in my 99 V6, but i have an offer for an LS2 from an '05 GTO & was wondering where i can find a wiring harness to fit? Or will the wiring harness from the LS2 fit for my car? Any feedback would be appreciated.
