Front accy brackets & pulley's
Old Apr 26, 2009 | 06:36 PM
TLewis4095's Avatar
Default Front accy brackets & pulley's
Almost finished....
Old Apr 26, 2009 | 07:22 PM
73 nova guy's Avatar
Thumbs up
sexy!
Old Apr 27, 2009 | 09:10 AM
garys 68's Avatar
Is the AC compressor bracket from Kwik or did you make it?
Old Apr 28, 2009 | 02:11 AM
Friday13th's Avatar
Where did you get the straight water neck?
Old Apr 28, 2009 | 05:46 AM
Pop N Wood's Avatar
Very nice work.
Amazing how wide that engine bay is.
Old Apr 28, 2009 | 08:30 AM
Danno74Z's Avatar
Straight Water Neck:
http://www.csr-performance.com/Merch...ry_Code=CP3SGC
Old Apr 28, 2009 | 03:51 PM
topher455's Avatar
I wish they would make one that uses the factory type thermostat.
I like the brackets. Will there be a set that includes power steering? Or uses the factory compressor instead of an expensive sanden?
Old Apr 29, 2009 | 03:08 AM
garys 68's Avatar
There's a local speed shop here in St Louis that has strait waternecks with the built in LS1 type thermostat on their shelf, Old Dog Hot Rods. Not sure who makes it though, maybe S&P. I think Katech makes one too.
As for the alternator/PS bracket, check out Kwik Performance, I'm pretty sure that's their bracket. The alternator bracket can be used with a PS pump.
There's a guy on corvetteforum, "Superpowers" that makes an similar AC bracket for the old GM compressors.
Old Apr 29, 2009 | 04:59 AM
TLewis4095's Avatar
Made them all. Danno is correct, The Woods family that owns CSR makes the water necks (they also own South Ga Motorsports Park). I could make one to fit the OEM compressor easy enough, just had the Sanden that came in the Vintageair kit. I should have the rack & pinion mounts finished this week and will post pics of it.
Just takes a little time and having the machining tools to do this stuff....most anyone thats a machinest can do it. Belt alignment took alot of time.
Old Apr 29, 2009 | 07:56 AM
topher455's Avatar
Cool. I actually made some brackets for my project but they are very simple and used 98 s-10 accessories. They are not as cool as those are though.
Old Apr 29, 2009 | 08:23 AM
garys 68's Avatar
Nice work. And you shined up everything.
I did my own too but sqeezed the accessories in a little closer. This is in a 68 vette.
What's yours going into?
Old Apr 29, 2009 | 10:48 AM
TLewis4095's Avatar
64 vette convertable.
Old Apr 29, 2009 | 11:17 AM
garys 68's Avatar
I thought the frame, A arms, coolant tank, etc looked familiar.
Old Apr 29, 2009 | 05:42 PM
TLewis4095's Avatar
Your 68 is gonna be NICE when done!!
Old Apr 23, 2010 | 07:24 AM
1976CamaroGuy's Avatar
I realized the OP is banned, but did he make those brackets himself?
Old Apr 23, 2010 | 09:16 AM
garys 68's Avatar
He said he did, but the design looks a lot like kwik performance brackets.
Old Apr 23, 2010 | 09:40 AM
bozzhawg's Avatar
Will the fuel rail covers fit with that top mounted A/c bracket/comp...... I know it should clear the alt side.....
Old Apr 23, 2010 | 12:14 PM
NemeSS's Avatar
all that hangs way out there.
