Need help with a/c ?????
Old Apr 30, 2009 | 10:30 PM
71 chevelle's Avatar
Default Need help with a/c ?????
I am going to run a 6.0l in a 71 chevelle. I would like to know what needs to be done to make the A/C work. I do not have the $$$$ to put in a complete vintage air system anytime soon. Can you guys help me out on a budget friendly way to use as much of the stock parts on the car and motor as possible.
If their is link that I may have missed please direct me to them thank you.
Old Apr 30, 2009 | 11:32 PM
bczee's Avatar
Does your chevelle have factory AC ?
I was able to get my Stock Chevelle system to work by just using the LS1 AC compressor... it does have a few set back due to the variable compressor. but that can be fixed or as I do. just live it it. I just sub the LS1 compressor, wire it up and re-did my AC lines.
Old Apr 30, 2009 | 11:34 PM
Yes....
Old May 1, 2009 | 08:11 AM
garys 68's Avatar
I went with the vintage air. But there's a guy on corvetteforum (Superpowers) that sells the old style GM compressor mount. I have not hooked up the AC enable or compressor disable from the computer to the AC system, I figured I would see how it worked without it first.
Old May 1, 2009 | 09:03 AM
3.1EyeCandy's Avatar
I've got SuperPower's AC Mount - works great. Nice quality. I'm using it with a factory AC Compressor from an 88 Trans Am.
Old May 1, 2009 | 09:45 AM
Does it work with the stock controls? or what are you using . How do you wire it, and pics please if you have any. As you can see I am looking to paint my car black and living in socal a/c for the family is the only way to go.
Old May 2, 2009 | 12:16 AM
G-Body's Avatar
sawzall wielding director
I used a truck compressor on mine, then I had lines made to hook to the factory El Camino a/c.
For the electrical side its a hybrid, the El Camino system controls 90% of it, but I did leave a hookup to the LSx computer so that it knows when the AC is on and can raise the idle etc.
What year/bodystyle haress/pcm are you using, I`ll let you know how to hook it up.
Old May 2, 2009 | 12:30 AM
I have a 03-04 6.0l motor other than that its all stock and has not be mod yet. I what to get the info, on what is needed first.
I have been on the buy twice method and cant afford to do that any more. The wife is not to happy as I was just going to upgrade the suspension. That was over a year ago and 6/k and the car is no where near completion.
If you can pm me or email @ projectsyckness@verizon.net
