LS powered Vega.
Old May 10, 2009 | 09:11 PM
speedy55's Avatar
Default LS powered Vega.
Has anyone put an LS engine into a chevrolet vega?
Old May 10, 2009 | 10:22 PM
V8Rumble's Avatar
Yep. There are threads if you search...
Old May 11, 2009 | 04:18 PM
speedy55's Avatar
ok thanks
Old May 11, 2009 | 06:03 PM
Rock_Daddy's Avatar
Mine should fire on the dyno this week and the rest of the car is just sitting and waiting for it. It could be running down the track in 2 weeks if I'm lucky.
If you have any questions go ahead and ask. I seem to hit evey issue possible.
https://ls1tech.com/forums/conversio...8-ls-vega.html
Old May 11, 2009 | 06:33 PM
speedy55's Avatar
where did you get the motor plate or is it custom cut?
Old May 11, 2009 | 06:54 PM
Rock_Daddy's Avatar
I have 2 LS Vega setups. One I had a generic LS plate just modified to for on the bars in the front.
I also have a 76 green Vega that originally had the regular V8 kit for a SBC. Where you weld the mounts on the body and the engine mounted brackets lay down on them. I had a plate made that laid right down on the mounts made for the SBC kit.
Here is a pic of each setup. Both were custom, the green one more than the purple one.
Old May 11, 2009 | 07:01 PM
Rock_Daddy's Avatar
The plate isn't that bad it's the exhaust and steering that is killer.
Old May 11, 2009 | 07:10 PM
speedy55's Avatar
I cant decide which way to go with mine. Mild build or take the plasma cutter to it and do tube chassis with a 6.2 twin turbo/powerglide 12 bolt combo. I geuss I will see what the money tree sprouts before I make that decision.
Old May 11, 2009 | 07:11 PM
Rock_Daddy's Avatar
Well if you do the mild you will just wish you did more then eventually do it anyway at twice the cost. Happens to me every time! lol
Old May 20, 2009 | 07:26 PM
speedy55's Avatar
Got any dyno results yet?
Old May 20, 2009 | 08:09 PM
Rock_Daddy's Avatar
I was short one O2 extension cable on my FAST XFI this week and had one sent over nigh to the shop yesterday. It should have got there around 3 today so I'm thinking it should start up on the dyno tomorrow.
Anyone want to guess at a number?
L92 heads with aftermarket springs.
Cam is 24x 25x and 625 625.
12:1 comp
416 CDI
Cary's intake with a 4500 flange and 4500 Accufab TB
Running on a FAST XFI system
Custom 1 3/4 headers that will not go past dumping at the collectors
Here is some more engine ****.
Old May 20, 2009 | 08:51 PM
S10xGN's Avatar
...Here is a pic of each setup. Both were custom, the green one more than the purple one.
Hey Rock,
I know you said "purple", but that looks blue to me. In fact, it looks like the Ford "Sonic Blue Pearl" (code SN) I used on my '72 LS-Maverick. Care to divulge the paint code?
Thanks!
Russ
Old May 20, 2009 | 09:04 PM
Rock_Daddy's Avatar
It always looks total blue in pictures for some reason but in person its grape purple. Not a hint of blue at all in person. Don't know the code, it was like this when I bought it. Even had a rear plate that said "Welches"
Old May 20, 2009 | 09:44 PM
cam75w/ls1's Avatar
Didn't spec the cam duration or mention nitrous. I'm guessing 575hp.
Old May 21, 2009 | 08:37 PM
SPDMETL's Avatar
625HP@ 8,000 RPM. Sweet cars ! I wish I fit in the damn things...
Old Jun 9, 2009 | 02:29 PM
Rock_Daddy's Avatar
So far today we are at 605hp @ 6500 at the crank. They aren't done yet but I bet its pretty close. Should be fun in a 2600lb car. I'm pumped!
Ended up with 617 at the crank
Old Sep 15, 2009 | 09:01 PM
speedy55's Avatar
any dragstrip numbers yet?
Old Sep 15, 2009 | 09:02 PM
Rock_Daddy's Avatar
9.54 is best ET 140.21 is best MPH car weight is at 2670lbs
Old Sep 15, 2009 | 10:48 PM
chevellepowered's Avatar
hey rock daddy where did u get that intake.. ive been looking for it on google, cant find one.... thanks..
never mind ive found it on ur thread,thanks,,
Old Mar 12, 2013 | 01:51 PM
philntx's Avatar
This one showed up in the Jeg's booth at the Detroit Autorama:
http://pinterest.com/jegsperformance...-jega-lsx-454/
