question on 5.3
Old May 21, 2009 | 12:53 PM
95greenmaro's Avatar
Default question on 5.3
How hard would it be to get a 5.3 in a 3000# car to run 9's? the 5.3's are found for so cheap I was thinking of running one, but don't know what the max is that I could get one to run
Old May 21, 2009 | 01:01 PM
NemeSS's Avatar
spray and a killer susp.
Old May 21, 2009 | 01:14 PM
i still cant decide on which motor to run. i will be on a strict budget for this build, and I am wanting to go with a carb setup. how much spray can a stock bottom end 5.3 hold and still continue to make passes?
Old May 21, 2009 | 01:31 PM
one fast zo6's Avatar
Default 5.3 nitrous
200 shot with a good plate setup!
Old May 21, 2009 | 03:21 PM
NemeSS's Avatar
spend on susp. and rear end. th350 and 4k stall. manual steering and udp.
a healthy 150-200 hit with race. and a some hiflow headers and exhaust.
will make for strong runner, but idk about 9's
Old May 21, 2009 | 03:30 PM
guess if i save up a little longer and get a 6.0 it would be easier?
Old May 21, 2009 | 03:36 PM
NemeSS's Avatar
or 5.3 with mpt70 with good susp. if u can pump around 500rw thru a th400 or th350 it should get dam near close.
ssick1's Avatar
yea 6.0 would be better handles good amount of nitrous and good for stroker
Old May 21, 2009 | 04:23 PM
a stock 5.3 with ls6 cam and springs with fuel and tc76 turbo, should pump around 700 rwh thought th350 and get you close,for cheap!!!!!!!!!!!!.
NO NEED FOR LOW GEARS,OR HIGH FLOW HEADS!
Old May 21, 2009 | 08:30 PM
ForcedInduction's Avatar
pushing over 650 rwhp here on my setup.
with parasitic loss through the trans that about 775 Crank HP.
on a 3000 lb car thats 9's all day
Old May 21, 2009 | 11:05 PM
$O$OE's Avatar
I thought about the same thing, 5.3carb on a 150-200shot somewhat good suspension on a 2900lb car(notch) with a th400/350 damn good stall gears and a meaty tire...but dont know if that set up can go mid 10's on juice...????
Old May 21, 2009 | 11:06 PM
$O$OE's Avatar
plus those 5.3s are everywhere! thats what makes it more tempting than the 6liter
Old May 21, 2009 | 11:14 PM
$O$OE's Avatar
and when you mean "cheap" what exactly do u mean as cheap? less than 6k?
Old May 22, 2009 | 11:10 AM
that is what is making it hard for me to decide on which set up to go with. i thought about the turbo route but dang that would be nearly 5-6k for a decent set-up
Old May 22, 2009 | 11:12 AM
what is the cost of doing that turbo set-up? would it work well using the truck manifolds flipped around? money's tight with a 13 month old running around the house
Old May 22, 2009 | 11:49 AM
digitalsolo's Avatar
My 5.3 with a mild cam and good heads made >400 RWHP N/A (though a T56).
Now, with a turbo on the same setup and 6-7 lbs of boost (intercooled) I ran 122 mph in the 1/4, on a first time ever test pass, picking up over 30 mph on the back half. Car should go 127-128 mph on the same boost if I get it better sorted.
5.3 is a great platform.
Old May 22, 2009 | 02:13 PM
what kind of vehicle is this in? looking at your sig i would guess an 88 rx7?
Old May 22, 2009 | 02:20 PM
Quick Sh0t xMLx's Avatar
That should be good for mid 10s at least. People in full weight F-Bodies/Corvettes are running 10s with that much power without a crazy suspension setup. Hell I saw a mean suspension full weight Camaro pull a 10.9x cam only(400 whp). I can see a nicely set up bolt on+200 shot 5.3 running a very very high 9 in a 2900 lbs car.
Old May 22, 2009 | 02:24 PM
will the stock bottom end hold up to a 200 shot?
Old May 22, 2009 | 02:41 PM
NemeSS's Avatar
your new mission is to make it happen and report back
