Ls1 into 66' Chevelle
I am having a hard time finding headers and motor mounts for the swap so i would like some help finding these items. Also in summit they have the painless wiring kit for Ls1's for $595 has anyone used this? If so how did you like it? I would also like to know if you guys think i should keep the M22 4speed in the car or put a TH400 in it and what do you guys think the price difference would be between the two behind the Ls1.
Also does someone make a fuel pump and wiring kit for a plug and play set-up?
I'm trying to use the BRP style Gen I motor mounts, the stock f-body oil pan, and a 4L60E. I think my setup is closest to Pist0lpete's setup (thanks btw!) I did the wiring myself which i'm done with but not yet tested. Took longer than I thought but I decided to retrofit a GM style fuse block from a Cavalier. Everything you need is in the sticky posts up top. Seems like the old A-body swaps is probably one of the most well documented.
Here's a pic of the mount adapters I made this wknd. The 9/16 hole seems a bit big but I just follow the drawings in the FAQs. I also added a countersunk M10 hole which wasn't in the drawing. We'll see i guess...
Here is what I have so far. I will be updating the writup on wednesday with more tech. and more pictures.
https://ls1tech.com/forums/conversio...lq4-4l60e.html
Should be a sweet swap, good luck
Pat
p
