LS2 Or LS3 Conversion into a 1998 Camaro Z28
What is the better swap an LS2 or an LS3 crate engine. Also I am hearing that the LS2 crate engine is discontinued from GM as a sold crate engine.
What else is involved besides changing the oil pan to an F body pan and the drive by wire to a throttle cable?
Any help would be appreciated. Thanks.
read me: https://ls1tech.com/forums/generatio...body-help.html
Stickies are your friend because so many have made this swap in their fbody, it is easy to find build threads or contacts that can help with any questions.
You can always check with your local Government Motors dealer. If you have a garage you should be able to get garage price on it. This is what I did and they even delivered it for free. This way you save on trucking costs. Good luck.
Rich
Rich
