carbed 5.3 made it to the track
Not bad for a 300 dollar junk yard motor.
I was getting 7.9-7.8 in the 1/8 running 12.00@115 in the 1/4 with 1.8 60ft. But I had a 5.7 and 3.36 rear gears
Stock Heads
Scoggin dickey springs
tr220-114
Thunder racing 7.4" pushrods
Performer RPM (cut down the divider)
Holley 750 hp
CPW 1.75" longtubes
TH350
shift kit
Fuddle Racing 3k stall
Ford 8.8"
Motive Gear 4.10's
Rebuilt posi w/extra clutches
Lakewood traction bars
275/50-15 Drag radials
5.3l stock heads
TSP224r 112lsa (.581/.581)
PAC 1218 springs
TR 7.4 pushrods
1.75" Stainless Works LT headers/Hooker catback
Proform 750dp
Victor Jr/MSD 6010
TH350
3600 stall
LS1 3.23 posi rear
full Spohn suspension
It's awesome to finally see people realizing the potential of the 5.3.
Horsepwraddict - What's your carb setup? Jets/PV/squirters/accel pump? Did you use the MSD 6010? Care to share your timing/MAP curves?
I use the MSD 6010. As far as timing goes, i have have it locked out at 29* from idle all the way up. I dont run any vacum advance.
i need to get my heavy pig out to the track..i'd be happy w/high 13s
-81 c10
5.3
stock heads
gmpp hot cam/ls6 springs
stock manifolds
gmpp intake
holley 650 dp
th350
2500 stall/shift kit
2000 LS1 from SS camaro
T-Rex cam
Patriot gold springs
Comp push rods
Full port job on the heads & decked .030
Victor Jr. carb intake
MSD 6010 from MSD not the eldebrock one
SLP underdrive pulley
ARP head studs and rod bolts
Th400 trans built
custom nitrous stall 3600
9in
5.13's
moser axles
spool
weld pro stars
drag shocks front and rear
mono leaf's
Oh and a 250 shot
Standard cab short bed harwood 6in. cowl lift off
Not sure what to expect hoping for some decent times my heads and intake on an LS2 made 644rwhp in a mustang coupe oh ya same came also
Best run
11.99
114 mph
1.88 sixty foot
best mph i had was 114.5. of the four runs i made all had MPH between 113 and 114.5
It was still in the 90's with high humidity. With good weather i think its a consistently high 11 second truck
