ls1 swap to a 94 v6 firebird
Old Jun 23, 2009 | 02:28 PM
94whtbird's Avatar
Default ls1 swap to a 94 v6 firebird
to do this swap wat all would need to be done?? how much would the engine and tranny cost??? would i need anything else for it?? and how long would it take a shop???
Old Jun 23, 2009 | 04:21 PM
miker82's Avatar
not sure what all you will need, but doing the same thing to a 2001 v-6 camaro. Just also need to know about the v-6 dash (will it work with the ls1 motor and harness
Old Jun 23, 2009 | 04:24 PM
miker82's Avatar
I was told that you have to use the v-8 dash and wiring harness or run the v-6 dash computer and sending units on the ls1 motor ????????
Old Jun 23, 2009 | 05:12 PM
NemeSS's Avatar
ther are various ways about swapping a ls motor.
gotta take budget into account, add ons,etc.
prolly cheeper to go turbo if looking for more power. easier to build a turbo system around your engine than ls swap.
Old Jun 23, 2009 | 10:08 PM
94whtbird's Avatar
but i have the 3.4 in mine which has around 160 horse with 155xxx miles i would have to rebuild th whole engine and if i did go turbo around it could i pull more horse than a ls1???
Old Jun 24, 2009 | 07:54 AM
the_merv's Avatar
Veteran: Air Force
Here is a link to mine..it's a decent amount of work.
https://ls1tech.com/forums/conversio...to-95-z28.html
Old Jun 24, 2009 | 11:17 AM
silver97z's Avatar
from the budget LS swap thread (sticky) you're probably lookin at about $1,500 for the motor (4.8 or 5.3). Trans probably going to run between $500-$1,000 or so depending on whether you're going with a 60e, 80e, or t56. You can use the V6 dash, but you'll need the V8 cluster, v6 has 120mph speedo while v8 is 160 I believe. You'll need the wiring harness and ecu if it doesn't come with the motor. LS1 k member.
Going from a v6 to v8 I'm guessing you'll need to upgrade shocks/springs/brakes possibly. I don't know if the rear in a v6 is the same as the v8...driveshaft maybe...possible fuel pump.
I'm just guessing off the top of my head...$3,000-$4,000 in parts easy, and that's buying everything used. Labor at a shop would be unreal is my guess, best if you can do the work on your own.
Old Jun 24, 2009 | 01:30 PM
the_merv's Avatar
Veteran: Air Force
Front Suspesnsion is the same except for the Springs..I would upgrade to the LS1 Brakes IMO.
Old Jun 24, 2009 | 06:22 PM
MelScrilla's Avatar
i heard that the v6 has a different tank than the v8 but i'm not sure either. I'm interested too because i dont have the money to buy a v8 but i can get a v6 roller for 1200.
Old Jun 24, 2009 | 08:21 PM
tektrans's Avatar
pm Firehawk441, he did it and his car is very nicely done. Fast too.
Old Jun 25, 2009 | 09:33 AM
slammed1500's Avatar
i did a 99 v6 - 01 ls1 swap
here is my list of things i swapped
motor/trans with egine harness
k-member
rack and pinion
sterring shaft from column 2 rack (v6 and v8 are diff.)
radiator
v8 gauge cluster diff years have diff fuel level readings
vette fuel filter ( it has a buit in regulator and return )
and i just upgraded my fuel pump 2 a racetronics pump
if i remember more i will post it but i think that was all
and i only had 2 add one wire 2 power bank 2 for the other coils and injectors
thats the only wiring i had going from a 99 v6 - 01 ls1
and other thing like LSD with gears , springs and brakes
and i upgraded 2 a aluminum driveshaft
Old Jun 26, 2009 | 06:59 PM
MelScrilla's Avatar
I guess the thing that always comes up is, "is it worth the money?"
in every 6 to 8 conversion thread someone usaully says that.
Slammed1500- about how much did it cost you to do the conversion?
I would be interested because there is a v6 roller around here for 1500 which i could probably get for 1k. Then i would have to save up for the rest of the parts and do the conversion slowly.
