LSX 1986 camaro
Old 02-06-2010, 07:20 PM
  #41
Spike-Z's Avatar
Wow man, what a clean car. And talk about one hell of a sleeper. Id put 14" steelies just for more stealth
Great job!
Old 02-06-2010, 09:28 PM
  #42
Northstar Camaro's Avatar
nice work!
Old 02-07-2010, 01:00 AM
  #43
7t9maliBU's Avatar
u said it once had a 2.8 i have a shell 87 camaro and i plann to do the same 5.3 swao but with a th 350 what modification to the motor mounts am i looking forward to and could u tell me me more about the interior swap?
Old 02-07-2010, 02:44 AM
  #44
the_merv's Avatar
Originally Posted by 1nasty86
naw man its been gone. lol but hows the 4l80e going? i thought about doing the 6l80e...
That 4L80E is a tight fit..good luck with a 6L80E..lol
Old 02-07-2010, 11:16 AM
  #45
Turd Gen Guy
1nasty86's Avatar
it was just a dream. a six speed automatic 86 camaro. thatd be a first
Old 02-07-2010, 11:18 AM
  #46
Turd Gen Guy
1nasty86's Avatar
i just bought the jegs swap frame mounts and the spohn trans crossmember and welded the frame mounts to the kmember. but i plan on ordering a tubular kmember in the next few days
Old 02-07-2010, 03:15 PM
  #47
1A Dan's Avatar
the more 3rd gen LSx'ers the better. A lot of guys run the spohn mounts, I'm gonna try the relocation plates myself. A lot of it seems to come down to whether you want to run A/C or not.
Old 02-07-2010, 03:39 PM
  #48
Turd Gen Guy
1nasty86's Avatar
oh i fully plan on running a/c
Old 02-07-2010, 08:52 PM
  #49
7t9maliBU's Avatar
THANKS! AND COULD U TELL ME ABOUTdoing the 4th en interior did u have any major problems that i should look forward to?
Old 02-07-2010, 09:06 PM
  #50
Turd Gen Guy
1nasty86's Avatar
yeah. the center console is a direct bolt in. i had to drill 2 small holes in the upper part where the dash bolts up top and 2 screws went in fine. it also bolts up to the steering column just fine. the lower braces were cut off.. i see no reason to have them. the heating and cooling was cut so it will be on defrost ar all times ( i plan on fixing that over the summer) the cluster and dash/headlight switch was the b*tch though. i could post up a diagram i followed from thridgen.org. the volt,speedometer, and tach were a pigtail off my wiring harness. and my oil pressure is one wire from the sensor. the 97 dash i have has the looks of the new dash with the 0-90ohm level sensor that is stock in the 3rd gen tank. so id go for atleast a 97 cluster. and water temp. is a 3 wire from an ebayer in flordia that has a pigtail for a guage. hope this helps
Old 02-07-2010, 09:26 PM
  #51
NemeSS's Avatar
good work.
Old 02-07-2010, 09:28 PM
  #52
7t9maliBU's Avatar
I APPRECIate the help.. did u have a donor for the interior or did u go threw a junkyard and the car i have has no electrical anywere so i was gonna get a reman ecu from my job but i have no clue wat to do for a harness any sugesstions?
Old 02-07-2010, 09:36 PM
  #53
Turd Gen Guy
1nasty86's Avatar
http://www.birdsandbowties.com/
this is a great guy to work with. paid 400 for the whole dash, cluster, wiring, door panels, console, and he said anything else i could carry. lol as for the wiring the oil pressure, volt, water, and fuel should not be a big issue. in sure you could pin into the connector in the pcm and get the speed and tach signal
Old 02-07-2010, 09:44 PM
  #54
Blownz28man's Avatar
So why'd you get rid of your turbo?
Old 02-07-2010, 09:48 PM
  #55
Turd Gen Guy
1nasty86's Avatar
too much b/s to deal with on a 2-3 day daily driver.
Old 02-07-2010, 10:05 PM
  #56
7t9maliBU's Avatar
ANother thing when u got the 5.3 did u have to change the oil pan to a 5.7 oil pan?
Old 02-07-2010, 10:18 PM
  #57
Turd Gen Guy
1nasty86's Avatar
yeap. bought it off tech. i used the f-body pan
Old 02-07-2010, 10:20 PM
  #58
7t9maliBU's Avatar
ok.. thanks mann uve been a big help anything else u can think that mite hel me let me knpw
Old 02-07-2010, 10:29 PM
  #59
Turd Gen Guy
1nasty86's Avatar
ok man. if you have any wiring questions or anything just pm me.
Old 02-08-2010, 04:33 AM
  #60
the_merv's Avatar
^^Back from when we were talking about mine..if I were to do a 3rd Gen I would use everything from my 1995 Car..Fuel Tank, Interior Wiring, Engine Compartment..everything. I have a feeling that would work pretty well.
Quick Reply: LSX 1986 camaro
