6L80E in a G-body?
It will be all worth it when I am done, and can't wait to run the paddle shifters through their paces.
Regards, John McGraw
From what I recall, the A-body pan is slightly lower/narrower than a G-body as it was a pre metric O/D transmission design. As I've seen/heard the T56/4L80 will pretty much interchange in anything '80's and newer with little or no massaging, the 6L80/90 should be a slip fit. This of course depends entirely upon whose motor mounts kit you use.
Mine will not be lowered.. it will be stock heightish so i don't have to worry about ground clearance.. I didn't have to touch my trans tunnel for my T56.. It is close but it clears.. I am also currently using the truck oil pan with no issues..
