DBW Gas Pedal mount 240sx
how did you guys with dbw setups / 240sx mount your gas pedals?
Im thinking of making a plate to mount to the original bracket but I was wondering if anyone has any pics of their setup
I'm having issues right now. My car starts and idles but I don't have any throttle response at all. I'm running a 2004 truck pedal, tac module and throttle body. I'm thinking about just removing it all and going DBC.
Truck pedal is different from the GTO or Vette pedal, I will have to Hack it and reweld it if I keep it.
That's kinda of what I was thinking. Sale all the DBW setup and pick up the cable tb and call it a day. Keeps me from having to cut up my hood support also, since the truck throttle control sits up higher.
Awesome build on fresh alloy of a LS14. He's using the corvette pedal with a bracket.
http://www.freshalloy.com/forums/sho...d.php?t=186918
Well. I took a peak at ruthlessdet's mount and decided just to make my own.
I like the way it feels. I put it as close to factory as i could.
WOT is about 3mm from the spacer i put in so it can be mashed and not suffer too much...
Everyone keeps telling me I should only have 1 wire going to the PCM because the altenator is a 2002 Z28. I really don't know what to think. The PCM and harness are from a 2004 Truck. It originally had 3 wires on the plug.
240sx Blue Pearl, great job on the pedal.
wouldnt a reliable PCM pinout solve your issue? btw i just found out that my pcm is "ok" vats removed and all that .. but my ls2 starts revs to idle, then quits....
