'98 alternator one wire operation???
Old Sep 16, 2009 | 08:26 PM
69chvl468's Avatar
Question '98 alternator one wire operation???
Can I use my stock 98 ls1 alternator as a one wire operation in my chevelle??
Old Sep 16, 2009 | 09:12 PM
Nissan LS240's Avatar
(Don't know if thiss will help because my car isnt running yet), for some reason the junkyard cut the alternator harness so i ordered a replacement connector that came with just one wire, the alternator should have a 12v battery wire and its case gounded, voltage regulator is built in, so it should only need one wire to power the coil, and i think the other wires are for voltage gauge and to turn off battery light when its charging not needed unless your car came with an ls1
Old Sep 16, 2009 | 09:21 PM
poconojoe's Avatar
If you put a one wire regulator in it.
One wire alternators only have a battery connection, the regulator is self-exciting, so it needs no other connections
Old Sep 16, 2009 | 10:02 PM
69chvl468's Avatar
Ok, mine also had the one wire harness. Would you put that wire to a key switch to excite the coil?
Old Sep 17, 2009 | 01:21 PM
69chvl468's Avatar
Anyone else have a take on this? If not, what other alternators could I use?
Old Sep 17, 2009 | 11:47 PM
G-Body's Avatar
sawzall wielding director
https://ls1tech.com/forums/conversio...aq-thread.html This should help.
Old Sep 18, 2009 | 07:49 AM
the_merv's Avatar
The one Wire goes to the PCM.. my 1999 Harness is a one wire Harness. I spliced into it for the Gauge Signal Wire for my stock Camaro Gauges.
Old Sep 18, 2009 | 04:36 PM
69chvl468's Avatar
Originally Posted by G-Body
Thanks! Very helpful info! Mine is a 98 standalone harness with a 98 ecm. Should be a easy hook up...
