Dyno Day TOMORROW!!!!! Taking bets....
Anyone got some guesses?
LS1, ARP hardware/bolts
GM Hotcam
Underdrive pulley
Sanderson headers
T70 turbo~ 82a/r turbine, .70a/r compressor
T56 6-speed trans
3.73 gears in a ford 8.8 rear end
Siemens deka 60lb/hr injectors
8psi if everything works correctly...
How Much Power do you all think it'll put down??? DYNO DAY TOMORROW!!!!!!!
Lets see who's closest!!!!
goin on a Mustang Dyno
GM Hotcam
Underdrive pulley
Sanderson headers
T56 6-speed trans
Closest to the #.
Well... I'm an idiot aparently....
I never put front O2 sensors in, because i was thinking i didnt need them. You dont need them if you're gonig Speed Density only. (deleting the MAF)
But i'm running the MAF
Alot more $ to go speed density tune.
IN CONCLUSION, i'm putting the front o2's in this weekend, and going back to the dyno on Tues.
well i dont plan on going real high hp~ so this should be good for me.
Ebay turbo 100% !!!!!! i love them!!!!!!! 225$ shipped. I've used many on different setups, and with the proper oil restrictor, they work perfectly.
.82 a/r exhaust, .70a/r turbine
Tuning day has been rescheduled for Tuesday.
8psi the way she sits, and 12psi most likely with meth injection (in a couple months)
stock ls1 with hotcam (?) = 320rwhp x 8/15psi = 490rwhp
with 12psi and meth, something like 320 x 12/15 = 576rwhp (if the turbo is up to the job) most likely not, therefor a bit less, 530rwhp
quite curious though, any build pics ?
^ Build pics
And the turbo said it should be good for 700hp~ so we'll see maybe
No Meth for a month or so. just 8psi dyno on Tues
LSA is not the deciding factor for Forced Induction...
Dediding factor is DURATION, which determins overlap.
Hotcam is mild, not a large duration, not bad overlap, and works great for FI, plus it has a cool idle!!!! hahaha.
I can't wait for Tuesday~
