Oil pressure
Oil pressure
I know alot of people have drilled and tapped the piece of the oilpan for an oil pressure guage, but can I just replace the oil pressure sending unit withan aftermarket peice that will work with a electric guage?
Why/why not?
Why/why not?
EFI or carb ?
The computer needs to see oil pressure if efi so swapping the stock wont work that's why people add the one on the oil pan.
if its a Carb setup you can replace with the sending unit for the gauge
I thought so too, but I was ordering my harness from speartech and asked about this. And they told me that it was not seen by the computer. If that was the case I was going to have them add a wire for a guage off of the computer. If I am mistaken please let me know
As G-Body said, you don't need it for the earilier Computers.. what I did was took the pressure sensor.. broke the plastic part off, drill and tap for the correct thread size of your after market or OEM sensor.. and use it as the adapter.. Cost Zero.. I have my OEM idiot light sensor at that top location using my home made adapter ..
