My 95 S10 Nitrious 5.3 Drag Truck project....
#64
So over all i didnt order those things because it simply seemed like a waste of money lol... Ya it makes things a bit easier but if you are attempting to do a swap notching the crossmember and cuttin flanges off manifolds and adding under a foot of pipe shouldnt be too tough...
#66
Got a little bit of stuff done today. No pics as of right now as nothing was too special. I got the fuel pump and reg/filter mounted inside the frame rail on the passenger side and measured out how much fuel line i need to order along with the couple fittings left to complete the fuel system.
Also got the flanges cut off the manifolds and did some clearancing needed on the drivers side a arm (just grind down an area to get more clearance). I need to get about 4 feet of exhaust piping so i can get everything figured out for angles then get them welded all up and get o2 bungs welded in them.
Would have liked to get more done today but kinda at a stand still until i order more parts. Plan on ordering up the fuel line and fittings, exhaust piping, pushrods, and some gaskets/bolts needed to finish up everything on the fuel system and motor this coming weekend. After that stuff is ordered i'll just need rad/fans, o2's, MAF, fab up a cold air intake, few misc small fittings bolts and gaskets, starter, shorter my driveshaft, wiring harness and a few small finishing touch things and the drivetrain should be done and should be able to be started then i just need to finish my interior up. Coming along very well and im very happy.
#67
looking good. i have an 88 dime i tore into and started a frame off build. i realized i wanted to do it right and take my time, so i tore into my other vehicle, a 96 v6 mustang. the mustang can get finished a lot sooner. itll be getting an ls1 which i have already. i figured id work on the bugs and gain the experience on the stang and then later do the s10.
your truck is coming along great. keep us updated
#69
Thanks for the compliments guys, things are coming along faster than I thought with my only income is my part time job and i have a two other cars both with over $100 payments. Hoping to have her driving by mid april with the cam only set up. Will post more updates this weekend after i order a few hundred bucks of parts =]
#70
build looks good man!me and my friend built a s-10 last winter.went pretty much the same route your going except his is a square body s10 with a old school 350 cagged out and gutted with a fuel cell in the back on bottle...got an idea for a cheap bullet proof rear end for ya.we used a rear axel out of a 80'-94' four cylinder 4x4 toyota pickup.they are built just like a 9 inch with larger axels than a 9inch.they are aslo 31 spline axels.they come with 4.11 gears factory just pull the thrid member out and weld the spider gears up.we picked one up for $100.my brother has built alot of toyota rockcrawlers.his has 38x15.50 tires and 5.29 gears and never broke one of these rear axels and so far the one in the s10 is going strong.
#71
Going on a shopping spree this weekend...
Bought so far-
- -6 pushlock hose for the fuel system
- all the fittings left i needed for the fuel system
- Volts gauge
- Battery relocation kit
Planning on ordering my wiring harness, ecm, MAF, o2's, rad/fans (LMK IF ANYONE HAS A SETUP), some more exhaust piping, Tach, aluminum for doorpanels and dash, and see how much cash i got left after that.
Yes all this is getting ordered this weekend! haha
#73
Ordered my harness, computer, map sensor, buncha gaskets, tach, air filter, and some other misc stuff. I'll be ordering more stuff tomorrow... I love spending money lol
#74
Ordered my gaskets, TB bolts, Exhaust manifold bolts yesterday. Just sent my money for an ls1 f-body rad/fan setup from a member here today. Tomorrow the plan is to take back some fittings i dont need, return my vette FPR/filter to replace it with an aeromotive adj reg...
I'm changing some plans for the fuel system. Will be doing a return style setup with a Bosch 044 pump, Aeromotive adj regulator and FAST rails, along with 60lb Injectors. I figured i might as well step up the Fuel system now for future plans before i used the stuff i got and can't return it...
More parts should be coming in this week. GOt alot of stuff to do on the truck so i'm headed out to the garage now...
#77
Did you order that black push-loc hose from Jegs? If so you CAN NOT use it for fuel. I learned this the hard way and when I bought(several years ago) mine it did not state in the description that it was not for fuel. The hose will break down and make a black goo that resembles used motor oil.
It sucks but I just had to order new hoses and I had to get the blue stuff from Russel.
#78
Nope that stuff there is the Russel hose...
Today i returned my Vette style FPR/filter and ordered my Aermotive Regulator. Also just ordered my Bosch 044 fuel pump. This week i still will be buying my FAST rails then next check will be ordering my Siemens 60# injectors...
Ran out of money again so no more parts again til my next check lol...
Can't wait for my harness and all that to come in this week!
