pulling wires from C2 fuse block?
Thanks for the help Ron.
I used three fuse housings linked together, bought them and the terminals from here:
http://terminalsupplyco.com/Store/Se...earch=12004943
They have a weird ordering system because they don't list the prices, you can either go ahead and order or send them a quote request. Here are the quotes they gave me for the part numbers needed to build the actual fuse block.
12004943 1.96/ea
12020400 .28/ea
12004568 2.14/ea
There is also a $20 minimum order
I got all the info from here:
http://www.lt1swap.com/fuseblock_obd2port.html
I would suggest buying more than you need, because after putting this all together I had planned only using one fuse housing...but ended up using three to put all my pink wires on separate fuses, I have two radiator fans output in that box too.
Dorman part# 85668 less then $3.00
Thanks
I have not looked there for the relays, relay sockets, although they might have them. The sockets from allelectronics are the only one's I've found that will link together with the fuse blocks.
Thanks
I also did not want to try and cramp all pink wires into one fuse block, and will probably order three also
