Heater Hose U-Bend for bypassing Heater Core
#41
taking note of this part; not sure how i plan to run the heater core lines on my swap yet, but will at least let me start the car (safely) and keep the green stuff in the engine instead of on the ground....
#43
Just an FYI for anyone out there who wants to loop the heater hose inlet/outlet from the water pump without using a hose coupler or a bunch of bulky fittings. I found a hose that works perfect.
Dayco # 87629 or Kelly-Springfield #S-4354. Not sure what the cross reference numbers are for Gates etc. Around $8-9 at most retailers.
This hose is a U-Bend hose with one side being 3/4" and the other side being 5/8". It's small, compact, and best of all simple. All you have to do to make it work is trim 1" off of the 5/8" side.
#44
