Heater Hose U-Bend for bypassing Heater Core
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Just an FYI for anyone out there who wants to loop the heater hose inlet/outlet from the water pump without using a hose coupler or a bunch of bulky fittings. I found a hose that works perfect.
Dayco # 87629 or Kelly-Springfield #S-4354. Not sure what the cross reference numbers are for Gates etc. Around $8-9 at most retailers.
This hose is a U-Bend hose with one side being 3/4" and the other side being 5/8". It's small, compact, and best of all simple. All you have to do to make it work is trim 1" off of the 5/8" side.
This is what I use, a cleaner look than the loop.
https://www.dormanproducts.com/cgi-b...tegory_list=:0
I have heard about a 50/50 response on wether you can block them off or not, I removed my water pump and then removed the stock fittings, (they are just press fit) and tapped the holes with a 3/8 and a 1/2 tap and cleaned out the water pump thoroughly and installed hex plugs for a even cleaner look than the U-hose method, Mark Campbell the owner of S&P is the one that recommended me this procedure, to date I have not had any type of cooling problems. I guess to each his own
I believe it is for warm up primarily. When I first fired mine up, the upper water outlet was hot while the lower one was still cold. The lower one is where the thermostat is so if it's not seeing any hot water, it's not going to open very quickly, once it's open, the bypass doesn't matter a bit.
I have a vintage air setup also. My plan is to install a 1/8 - 3/16" transfer hose between them for a small amount of bypass but still allow enough pressure for water to be forced through the heater core.
