street and performance headers
Old Dec 21, 2003 | 06:10 AM
Shaky2ls1's Avatar
Default street and performance headers
has anyone used street and performance headers
http://www.hotrodlane.cc/newhtml/ls1headers.html
I need a set for a 66 nova ls1. heights front end project. and I was wondering about the quality and fit ? if anyone has any recommendations ?
I really dont want to have to get a set made. thanx for any replies
Old Dec 21, 2003 | 03:54 PM
gEtyOPaPiOn's Avatar
When I Got My Headers From S&p The First Time They Sent Them Tach Welded ...to Make Sure If They Would Fit Then Sent Them Back With The Correct Fit Mods Then Got Them Coated ....it Was Like A 6 Week Process ...nice Headers
Old Dec 21, 2003 | 03:56 PM
WHEN I GOT MY HEADERS FROM S&P THE FIRST TIME THEY SENT THEM TACH WELDED ...TO MAKE SURE IF THEY WOULD FIT THEN SENT THEM BACK WITH THE CORRECT FIT MODS THEN GOT THEM COATED ....IT WAS LIKE A 6 WEEK PROCESS ...NICE HEADERS
Old Dec 21, 2003 | 04:29 PM
Rod G's Avatar
I spoke with the guy in the header dept. at S&P on headers for my 79 elcamino. I explained to him how I had used the original 99 camaro mounts and made my own stands on the crossmember. The headers fit and finish are fine.
Rodney
Old Dec 21, 2003 | 07:11 PM
99 Black Bird T/A's Avatar
FWIW
Their headers might be ok on a stock engine...but I don't like the 1 5/8 primaries they insist on. I don't like that stubby collector that choaks down either. They can't build a set with 1 3/4 primaries because they buy everthing pre-bent in 1 5/8 tubing.
At the LS1's power levels you need a 1 3/4 primary not a 1 5/8 like Street & Performance says is ok. If you going to add a cam or do other bolt on's you'll want a 1 3/4 primary IMO.
I discussed their headers in detail with them for my 91 RS. Talked to about a 1/2 dozen people before talking to the right person that knew the answers to my question. What header for my 91 RS w/LS1.
S&P also told me, their headers will fit IF you use their motor mounts. They had no idea if anyone elses motor mounts would would work when using their headers.
I wasn't inspired with confidense to say the least.
I found a set of used extrude honed ported 2000+ manifolds with 1 3/4 primaries that I'll go with until I can get a custom set of headers done for the RS.
Good Luck
Old Dec 22, 2003 | 12:18 AM
Shaky2ls1's Avatar
thanx for reply but unfortunately I dont have the option of faxctory manifolds I tried them all, It was what I prefeered in first place. Headers from S&P are
the only ones that will fit,so unless I want to get some custom made they will outflow stock exhaust manifolds till then. thanx guys
Old Dec 22, 2003 | 05:07 AM
67pete's Avatar
I bought some Hedman Block Huggers for my '67 Nova with the Heidt's and they fit...however the finish, actually lack of finish, is bad !!! Mainly that the welds are incomplete and the tubes are welded on the inside of the flange...doesn't make sense to me! May bite the bullet and build my own.......
Old Dec 22, 2003 | 10:23 AM
Shaky2ls1's Avatar
I take it you had no luck with stock manifolds at all ? did u try the ls6 manifolds by chance ?
Old Dec 22, 2003 | 12:13 PM
Steve1969LS1's Avatar
I bought a set of S&P headers from a member here (Robert).. the fit and finish are great but I do wish they were bigger tubes.. im running a gearbox setup so these were about my only option. I will have to take a little material off the block (trans flange) to make them clear good.. will update once they are actually in the car Here is a pic:
Old Dec 22, 2003 | 01:05 PM
67pete's Avatar
Unfortunsately Camaros are different then the pre '68 Novas.......
The stock '99 Camaro manifold, on the passenger side hits the sub frame to body connection with no chance of grinding, drivers side is OK. I've cut the manifold open hoping to reweld it at a different angle but being a pipe inside a pipe is making that difficult, not a good welder to begin with...still haven't totally ruled that out yet either.
The LS6 Vette manifold hits the cross arm suspension mount, no grinding here either, however an angled spacer for the flange might work.....
Old Dec 23, 2003 | 05:13 AM
Shaky2ls1's Avatar
thanks Pete. I know this is off topic but here it goes anyway, hey was your nova auto or standard ? just wondering what to do for the switches needed for park and neutral (not neutral safety switch) as far as I know they change the idle a bit. any suggestions ?? stock camaro shifter maybe ?
Old Dec 23, 2003 | 06:40 AM
67pete's Avatar
I would say to get as much of the stock parts from the donor car including switches and evap canisters etc. Also would suggest the "Helms" manuals, as these are very detailed for the specific year engine.
My particular application is using the manual T56 trans which is self contained. Also the '67 was an automatic trans.... but I'm going to replace the column with the Camaro unit, which will include the cruise control along with the radio control option. I want to make the car as friendly as possible for normal everday use.
Old Dec 23, 2003 | 04:58 PM
Rod G's Avatar
I used a stock floor shifter and console out of a monte carlo ss on my elcamino. 3 micro switches and about an hours worth of fabrication. One for neutral safety, one to tell pcm when car is put into gear, one for back-up lights. About $8 for switches, works like a champ.
Rodney
Old Dec 23, 2003 | 05:21 PM
Shaky2ls1's Avatar
sweeet thanx for info i was hoping it was gonna be that easy
