My 67 camar0 LS1/4l60 swap thread
Old 03-28-2011, 06:25 AM
  #241
c6matt's Avatar
Originally Posted by firehawk68mcleod
A few questions, first, where did you get the ls1 brake conversion brackets and how much? second, how do you like the ebay a arms? do they seem legit and well build.. i thought bout getting top and bottoms.. last, what trans mission crossmember did you run? thanks
street and performance crossmember, if I were to do it again i would get the bowtie overdrives one... The ebay arms seem like solid pieces, I read all the threads on camaros.net and it seems most of the concerns/issues were with the early run of them. I will be keeping an eye on them though. Th brackets were $60+shipping and i got them through the guy listed on David Pozzi's site
Old 03-28-2011, 02:44 PM
  #242
firehawk68mcleod's Avatar
I was thinking of doing an ls1 conversion brake set up on my 68 camaro ... what all does it take to do this.. the brackets of course but can u still run the factory 68 rotors ... i have a hole set of ls1 calipers
Old 03-28-2011, 04:44 PM
  #243
c6matt's Avatar
it would be a waste, the bigger ls1 rotors are a huge part of the package. get a set of drum hubs turned down and get some ls1 rotors.. and the position of the oem rotor will be off to all the availble brackets..
Old 03-28-2011, 04:48 PM
  #244
bmf5150's Avatar
I got a set of drum hubs from a 70 chevelle,can I use stock spindles from a 68 Camaro front disc brakes?
Old 03-28-2011, 04:52 PM
  #245
c6matt's Avatar
yep, you will need to put some custom spacers (washers) to use the adaptors, (i did) but other than that it should work.
Old 03-28-2011, 05:21 PM
  #246
bmf5150's Avatar
Cool,that's what I was not sure of!!
Old 03-28-2011, 07:49 PM
  #247
c6matt's Avatar
oh and find about 5/8" longer 5/8" fine thread bolts for the top mount, that took 2 or 3 days for me to source...
Old 03-28-2011, 09:03 PM
  #248
So i have drum brakes now... do you think they have coversion brackets for drum spindles and what exactly do you mean turn the drum hubs? turned so the ls1 rotors slid onto the drum hubs/.. what brand of ls1 rotors did you buy? drilled or slotted thanks
Old 03-29-2011, 06:58 AM
  #249
c6matt's Avatar
I bought drilled and slotted off ebay... yes, you need to turn the drum hubs to fit inside the ls1 rotor. you will also need 1/4" longer wheel studs. Go to autozone and ask for 79 corvette wheel studs.. they work great. the brackets are the same for either spindle, you will need to grind your drum spindle, or space out your disk spindle, both are easy ...
Old 03-29-2011, 11:26 AM
  #250
bmf5150's Avatar
cool.so u can use either spindle,didnt know that!!awsome info!!thanks
matt!!
Old 03-29-2011, 07:18 PM
  #251
c6matt's Avatar
Turned drum hubs with new bearings and 79 corvette studs.
how the bracket bolts up
sexy
much Better
And the all important inverted flair to bubble flair adaptor so the stock lines bolt up to the 4th gen rubber lines
Old 03-29-2011, 08:00 PM
  #252
bmf5150's Avatar
Looks great,where you get adapter for flare To bubble flare fittings?
Old 03-29-2011, 08:54 PM
  #253
Gus_Mahn's Avatar
Nice build. I read the whole thread. I have two questions. Does your car still make decently tight u-turns with the 3rd generation F-body steering box? I'd read the internal stops are too tight for an A-body which make the turning radius suck. Some guys were using Jeep Grand Cherokee boxes because the stops were looser.
Is the internal tank pump really necessary? I know some Fox body Mustang guys are using a single external Walbro 255 external pump with a stock carburator style pickup. Some will just run a piece of rubber hose to the bottom of the tank from where the fuel pump was connected. On fast cars they add additional 255 pumps in parallel, and I've read up to three on a 8 second car. I've read of one external 255 in the 10's and is almost silent and is inexpensive, but did have a larger than stock pickup tube installed. These cars all have return style regulators. What do you run?
Old 03-30-2011, 06:29 AM
  #254
c6matt's Avatar
NAPA, I'll try and put the part # up in a bit..
U-turns are fine, although my car is rear steer, and the a bodies are front steer..
Do I have to go intank.. i guess its not a must, but I wanted some baffeling around the pickup (dont want to lose fuel pressure at the strip) and its quieter/more refined.. I looked at doing an external pump, after weighing the pro's/cons I decided the in tank was the best fit for my car. I ran the intake spectra pump and a corvette return style regulator when I was NA.. now I run an aremotive 1:1 boost refrenced regulator with -6 lines and a walbro 255lph pump in the spectre tank. I may be going twin pumps shortly, as I am turning up the boost. Or i may add a boost-a-pump to the walbro.
Old 04-04-2011, 12:06 PM
  #255
bmf5150's Avatar
How the brakes turn out?
Old 04-04-2011, 12:41 PM
  #256
c6matt's Avatar
they are all installed, Had an unexpected delay missing the metric bolts to mount the caliper brackets to the adaptor. I finished it all up yesterday, just have to bleed them and the car should stop again. Have to dial in with the adjust perp valve once the roads dry out.
Built 4l65 is ordered (not sure if i can mention who's I went with, he is on the forum very activly and have a great rep, but not a sponsor) so that and the SFI flywheel should arrive this week, then I get it aligned, put it on the rolls for a tune with the new pullys...and I should be ready for powertour. with a dependable ~500 RWHP...
Old 04-08-2011, 05:50 PM
  #257
bmf5150's Avatar
What's difference between 4l60 and 4l65??
Old 04-08-2011, 07:30 PM
  #258
c6matt's Avatar
the biggest change is the 5 pinion planatarys..
Wooo woo! Got a big package!
Of course..
Old 04-08-2011, 07:59 PM
  #259
bmf5150's Avatar
Nice!
Old 04-08-2011, 08:59 PM
  #260
icemanrd19's Avatar
whats a camero?
Quick Reply: My 67 camar0 LS1/4l60 swap thread
