Mustang swap ?
Old Feb 11, 2010 | 04:00 PM
dmracing's Avatar
Default Mustang swap ?
What radiator are you guys suing?
Old Feb 11, 2010 | 04:31 PM
djquik88's Avatar
F-body Rad and fans.
Pretty much a direct swap.
Old Feb 11, 2010 | 06:24 PM
danbap's Avatar
got any pics?
Old Feb 11, 2010 | 08:05 PM
djquik88's Avatar
You will have to drill about a 3/4" hole beside lower rest pad on the passenger side. This will be clearance for an alignment boss sticking out of the radiator. Other than that, it bolts right up like a stock fox radiator. I have no pics of the hole , but once you get a radiator you will know what I'm talking about.
Old Feb 11, 2010 | 08:29 PM
dmracing's Avatar
Heres the nub
Old Feb 12, 2010 | 01:49 PM
danbap's Avatar
why did you guys swap to the f body radiator over the fox? did you have cooling problem?
Old Feb 12, 2010 | 02:19 PM
orangenotch's Avatar
A stock radiator will work with 4 cylider hoses cut to fit.
Old Feb 12, 2010 | 06:09 PM
getsum27's Avatar
i used stock 99 camaro radiator and fans
i didnt have to drill any holes or anything and used stock f body radiator hoses..... no cutting required
doesnt get much easier than that
Old Feb 12, 2010 | 06:39 PM
dmracing's Avatar
Got any pics?
Old Feb 12, 2010 | 10:40 PM
djquik88's Avatar
It came with my motor and trans. The F-body fans mount directly to the radiator. Very nice set-up.
Old Feb 12, 2010 | 11:18 PM
danbap's Avatar
i might look into getting a rad/fan set up, thanks.
Old Feb 12, 2010 | 11:39 PM
Palomba's Avatar
What years/cars are these in? I will need a setup in my F150 for the lq9. Are the electric fans stock too?
How are you all wiring in your fans? Through the pcm? Or a switch in the car?
