Cold air intake and filter question
Old Feb 13, 2010 | 10:27 PM
69chvl468's Avatar
Question Cold air intake and filter question
I have an LS1 in my 69 chevelle and I'm stumped on what I should do for an intake set up. I saw some universal kits out there, but they just look cheap. Any ideas? maybe some pics on your set up?? Any help would be great. Thanks. And also, is there a upper radiator hose out there that will work with my swap?
Old Feb 14, 2010 | 07:43 AM
usc2001gc's Avatar
I'd be interested in this also. I'm in the process of putting a LS2 in my 71 Chevelle. I was looking at possibly going the the spectre components, but I wouldn't mind finding something that looks a little more OE.
Old Feb 14, 2010 | 08:48 AM
55chevy's Avatar
In my '55, I used the snorkel tube from a early LS GTO and picked up a spectra filter at my local O'Reillys store. The snorkel tube has the (2) sensor ports and makes it easy to install. I just changed to a K&N filter because the Spectra was a little fatter and wouldn't clear the A/C compressor when I added the a/c.
Here's a picture before I changed the filter. Good luck!
Old Feb 14, 2010 | 09:10 AM
55chevy's Avatar
I should probably add that the Spectra filter says it is not designed for street use so I don't know if it will pass emissions testing. I'm sure the K&N is a much better filter if you are going drive the car in a dusty enviornment. Once you get the snorkel tube, you can go online to K&N and find a filter with the dimensions you want. My new filter is jegs part # 599-RU-3620.
Old Feb 14, 2010 | 12:51 PM
69chvl468's Avatar
Thanks, I saw on of those on ebay for 74 bucks... and what radiator hose did you use??
Old Feb 14, 2010 | 06:31 PM
ggriffin59's Avatar
I've been researching a budget-friendly solution to the cold air intake myself. I found one reference to 5 inch stainless pipe bends grafted together with the MAF in-between. Anyone out there have a source for the pipe & connectors or info on the tech issues?
Old Feb 14, 2010 | 06:53 PM
Palomba's Avatar
I made a custom Intake out of home depot products for like 30 bucks, used the rubber/silicone hoses from the plumbing section for my elbows and couplings and some of the tighten down metal bands, A straight air intake piece from auto zone with a filter.
Old Feb 14, 2010 | 07:00 PM
thunderstruck507's Avatar
jagsthatrun.com sells rubber bends and things that look and fit nice
then I put a k&n on the other end
for a radiator hose, get one for a 70s buick rivierra with a 350 diesel engine, perfect fit...do a search and I have a thread about it based on someone else's guess that it should work
they had the hose in stock at my local autozone
Old Feb 15, 2010 | 12:11 AM
Palomba's Avatar
This is what i came up with when i had my 2008 F150. I utilized the stock air filter housing just modified it. The 90 i got from home depot and the clamps as well. All in the plumbing section.
Old Feb 15, 2010 | 08:25 AM
rockytopper's Avatar
Here is another recent thread with the same subject. Several chevelles even a functioning coil induction.
https://ls1tech.com/forums/conversio...ir-intake.html
Old Feb 15, 2010 | 01:34 PM
Klimaxx's Avatar
http://www.siliconeintakes.com
for the red 4 to 3.5 elbow, and red 3.5 to 4". Got an 18" long, 4" polished aluminum tube off ebay, and a fram dryflow cone with a 4" inlet off ebay. it was about 90 bux alltogether.
Old Feb 15, 2010 | 07:53 PM
80 MONZTA's Avatar
I picked up an air filter box from a 4.3l S-10 (dirt cheap), and some tubing from intakehoses.com. I am planning on opening up the lower front of the box and adding a chute between it and an opening below my headlights to get a ram air effect.
I am wondering if the S-10 size filter will be large enough for an LS-1, any opinons??
Old Feb 16, 2010 | 03:29 PM
69chvl468's Avatar
Looks great, Ya I will try that radiator hose. What year 70's rivierra?
Old Feb 16, 2010 | 05:53 PM
Monte_LS3's Avatar
Default Monte Cold Air Intake
Cold air inlet a la John Bzdel.....
Attached Thumbnails Cold air intake and filter question-img_0037.jpg   Cold air intake and filter question-img_0461.jpg   Cold air intake and filter question-img_0473.jpg   Cold air intake and filter question-img_0464.jpg
Old Mar 15, 2010 | 08:24 PM
69ChBuLQ4's Avatar
Its funny that the home depot was mentioned as a place to find air intake tubing because I read an article in carcraft that said the same thing:
http://www.carcraft.com/techarticles.../photo_29.html
They said someone noticed it, but they thought the person worked at home depot
S&P makes little square filters you just put on your engine and you don't have to build an elbow. This doesn't flow air very well I read cause the flat front plate blocks it. I was wondering, could you just put a cone shaped k&n on your air flow sensor and call it good?? maybe it won't fit, id like to know cause im doing an lq4 into a 69 chevelle too
