240sx ls1
price list-
car-600
sikky oil pan kit-1750
1 7/8 headers- 700
wiring harness-400
pcm-150
fuel- i got told a 255 pump and vette filer- 150
serpentine assembly-?????
im guessing around the 3500 price range... but then idk what im going to do about exhaust. please share some of your guys built sheets and suggestions!
thx seth
You completely left out the trans, DS and mounts. Expect $2-400 for your header back system depending on how complicated it gets. More if you dont DIY
Swaps get expensive fast
Mounts, DS and other camaro stuff likely wont fit in your nissan. Expect to shell out to make stuff work
The $2-400 estimate was for a simple box of bends, a few strait pieces, handful of hangars and cost of wire/gas/power for the day youll spend building the exhaust. Any kind of kit will be more
One thing to think about on the 240SX is brakes. The stock brakes suck with stock power. It gets much worse with V8 power. I have 300ZX brakes on mine and with the lines, used calipers, new rotors, new pads, and parking brake assembly I have right at $1000 in my setup. I also found out that once I got into it that my stock brake lines were rusty and were not safe. I ended up installing stainless lines throughout the car which obviously were more than steel but there would still be a cost associated with the replacement.
Also consider suspension. These cars are old. The bushings are more than likely worn out as well as the ball joints. I spent $300 on poly bushings and about $100 on ball joints.
The rear can also be an issue. You can get junk yard rears with VLSD for anywhere between $100 and $300. If you put a mechanical LSD in then you can be in for close to $1000. The Q45 rear is better for the V8 power since it is a 3.54 gear. This is what I have in my car but it ran me nearly $500 for it.
My car also needed wheel bearings. They come as an assembly from Nissan. It was about $800 for all 4.
Oh and EFI fuel line is expensive. I had about $50 there and you need several Russel fittings to go to the Vette regulator and to the fuel rail.
Exhaust can eat you up quick too. I built mine out of mandrel bent 3" stainless with V-Band clamps and long tube headers. After it was all said and done I ended up with about $2000 in it.
Then the hose clamps, heater hoses, vacuum lines, cold air intake, wiring, Dakota Digital box, and all the other crap adds up quickly.
Now obviously I spent a lot more than I absolutely had to but I wanted a car that was reliable so I replaced anything that I thought was worn.
Personally I would save a little on that kit and do some of it yourself. I bought Hinson headers, modified my cross-member myself, and used Vette motor mounts that were donated by a friend. Also built my own trans cross-member. It really isn't that hard. The driveshaft can be had from the driveshaft shop for a reasonable price. Oh I also bought the Hinson radiator and some electric fans.
I really wouldn't go at this swap without $5000 to $6000 to spend. I honestly have about $40,000 in parts in my 97 240SX which has a book value of about $7000. All that and I still need to do more suspension work, finish my A/C, and work on my cooling system some more. Oh and my T-56 is about to die so I'll be spending another $3000 on a trans real soon.
I don't want to talk you out of the build I just simply wanted you to realize where the money can go and quickly. Hope you build it though as its a blast to drive.
my budget was 16k then it went to 25k and am at around 35k now
only 2k in labor having long block assembled(blueprinted and balanced 327 sbc, torque plated, etc.).
not done. but i also had to convert to fuel injection which alone is costing 4k
to make it legal.
things add up quick
radiator? radiator hose, fans, relay(fan controller) primer if you are welding or using any mild steel, cutting grinder bits, nuts, bolts, washers,
fabricating the trans crossmember is not hard like sierrac3 said.
if you are going to stay with just getting the motor in then the budget can stay close to what you are hoping for but chances are you are going to want wider wheels for traction, some sort of limited slip diff(even J30), at least q45 brakes in front with upgraded pads and rotors in rear. the bushings given that they are old as hell now. I personally replaced every bushing on the car including the the one in the steering column, it is now aluminum.
I left out a lot of mods i would like to do and went cheap on things like seats for now. megan racing instead of bride.
good luck
For that much, Id buy the $30 in steel and build my own
Also I agree the mounts for these cars are CRAZY easy to make yourself. i have a whopping $35 in steel to make BOTH the engine mounts and trans mount. Add the Urethane Trans mount ($40) and some Flexane and metric All-Thread for the front motor mounts ($60) and the steel to mod the X-member ($10) I have a total of $145 plus the cost to powder coat it all. WAY less than the 500 or so people ask for the "Kits" But if you dont have welding knowledge or access to a welder then I guess the kits are an OK way to go.
Here's a few examples of the higher-priced items:
Hinson Cooling kit: $575
Aluminum Double Pass Radiator
High Output Electric Cooling Fan (2)
Upper & Lower Radiator Hoses
Steam tube Hose and provision
Radiator Cap
Hinson Engine Harness simplification- $315
Headers are going to run you between $650-$950, on average. Unless you go custom-built.
The fuel system will be around $500 most likely.
I am personally going with the Sikky mount kit, oil pan, and headers. My exhaust will be custom from the downpipe back... The Dakota Digital Speedometer correction is $80.
If you have money to spend, I say go for it. I cannot WAIT until mine gets finished! It'll cost a pretty penny, but you gotta pay to play right? Good luck man!
And when I say I research for good deals I mean it, my costs of 6k include buying the 97 240sx and even tagging. But I did find my Kouki for $400.
