D.b.w question?
Old Mar 11, 2010 | 08:46 AM
dmracing's Avatar
Default D.b.w question?
I have a 2006 GTO LS2 and want to convert from dbw to cable. Whats needed besides changing the throttle body. Anything need to be done to the PCM.
Old Mar 11, 2010 | 08:57 AM
garys 68's Avatar
You'll need to add IAC and TPS for a cable setup. Not sure what needs to be programmed for that to work.
Old Mar 12, 2010 | 12:12 AM
G-Body's Avatar
sawzall wielding director
You may need to switch PCM`s. Not many of the green/blue connector PCM`s have IAC drivers. Check in the PCM section IIRC there is a thread in there listing the service #`s for the ones that do have IAC drivers
Old Mar 12, 2010 | 02:20 AM
rsz288's Avatar
If its an LS2 GTO you have an E40 ECM and you are SOL on changing to a cable throttle with this.
Old Mar 12, 2010 | 06:35 AM
dmracing's Avatar
So, I change out the ecm and wire harness. Or can I modify the harness. Or, Do I just try to mount the pedal in the Mustang? Has anyone done this?
Old Mar 12, 2010 | 07:56 AM
garys 68's Avatar
Why not use the pedal? As long as it's not made by Toyota, it should work fine.
Old Mar 12, 2010 | 08:26 AM
dmracing's Avatar
Didnt know how to mount it.
Old Mar 12, 2010 | 08:27 AM
dmracing's Avatar
Old Mar 12, 2010 | 08:34 AM
garys 68's Avatar
I've got a pedal from a truck LQ9. It just bolts to the firewall.
Old Mar 12, 2010 | 10:06 AM
fptransport's Avatar
just fyi , when bolting the pedal to the firewall, b4 you installed, cut the "new" pedal since it has a weird long shape, cut it very short almost at the sensor , then cut the "old" pedal and weld the old to the new part , and when you make the install it will look just original... thats what I did but mine was a pedal from a truck so it might me different
Old Mar 12, 2010 | 10:15 AM
bozzhawg's Avatar
My 2006 LS2 GTO pullout has a E40 pcm......... The E40 is a 24x.... problem is yes in theory, he should be able to convert... but it would cost you too much money to convert, cost meaning $$, time, and headaches just to try to convert........ Your talking about swapping the entire throttle system and possibly having to swap to a LS1/LS6 ecm..... How much would that cost you, is my question? I just left mine alone and stuck with the DBW plug and play.... No extra expense unless there is no salary cap on your build......
Old Mar 12, 2010 | 10:25 AM
bozzhawg's Avatar
I took the pedal assembly out of the 2006 GTO, the pedals are actaully nice... He should have just ****** all of that out of the donor car......... I even took the brake too.... I stripped that GTO down.....lol I even took the driveshaft, All the parts I don't use, I said I would sell it on craigslist....lol
Old Mar 12, 2010 | 10:30 AM
dmracing's Avatar
I got everything.
Old Mar 18, 2010 | 08:40 AM
98SuperchargedLs1's Avatar
just stick with the dbw.. alot of people like it. and no extra expense
Old Mar 18, 2010 | 12:45 PM
davev78's Avatar
It's easier and cheaper to use the DBW set up you have... plus now you can easily add cruise control.
