in search of 11's N/A
Ok, so im new to the ls1 game. Just about a month and a half ago, i purchased a ls1 longblock out of a 2002 T/A with a broken head bolt for cheap
I stripped the engine bay in my 96 v6 mustang and then just sat on the idea for the past month.
well tis past week, i came across a complete ls1 out of an 02 T/A as well, with wiring and computer too.
for $1,100!!
60k miles
as figured, it has a ls6 intake and when i brought it home i searched the block number and found it to be an ls6 block!!
so now to my question, im looking for low 11's on motor and mid 10's on a 150 shot of juice.
is this attainable?
my planned mod list:
1 3/4 351 swap LT's
ls6 intake (obviously)
ported TB
4.10's
cam
stall
weight reduction
sticky tires
aftermarket rear control arms
so is this good enough? im guessing the car will weigh in at around 3200-3300
it wont be exactly a daily, but i do want it to be reliable on the street..
for cam and stall, i was thinking in the lines of a Trex and a 4000 stall
but i know there must be better options
on a side note, i was able to modify the stock 3.8 mounts to work with the ls1. just need some minor adjusments for alignment
98 motor/4L60e
TSP225 cam
Comp 918s
Yank ST3500
3.73 gear
1 3/4 headers, 2 1/2 exhaust
Good luck with your project!
BTW if you are interested i have a PT4400 converter for sale, its too loose for my combo.
98 motor/4L60e
TSP225 cam
Comp 918s
Yank ST3500
3.73 gear
What's your race weight?
Whats your mustang weigh? A4 or m6?
Here are some comparisons of ratings:
TH350 157lbs
4L60/4L65-E 160/176lbs
TH-400 190lbs
4L80-E 260lbs
So if weight reduction is the goal, you won't be doing it with the 4L80E
If budget is the goal forget about it... The converter for the 4l80E is atleast $600-$700 min......
I just don't trust reving up a motor with and adapter on the nose oe the converter and flexplate... You will need a flexplate too for the 4l80E since their converters are 6 bolt....
PS one option is to have a converter made 4l80E tranny side/ 4l60E tranny side.... but I would be suspect of the duribility..
Aslo on the valve train loss issue and just for conversation... A lot of die hard racers use TH350 do to less parasitic loss vs even a TH400..... But the rule of thumb is that the TH400 is a stuffer unit, but a well built TH350 will handle the power....
The other thing to notice is the gear spread..... Some guys do not like the first gear of the 4l60's and the gear spread......
Some like the 4l80e gear spread.....
So with everything there are trade offs and compromises......
