AWD Conversion???
Old Jan 9, 2017 | 05:40 PM
  #41
chuckd71's Avatar
No idea but I'd bet someone on performancetrucks.net would know.
Old Jan 10, 2017 | 09:34 AM
  #42
Tony Delerme's Avatar
Thank you Chuckd71. Will ask them.
Old Jan 12, 2017 | 12:38 PM
  #43
ss454327's Avatar
Originally Posted by 1320
They are very very strong. Ive heard they are rated to 1000 hp, but to me thats not a rating. It would depend entirely on the load, weight and traction.
Some of the ss silverado guys have run them with nitroused procharged 427's around 1000hp. They are sure alot stronger then most transmissions. I got a rossler 4l80e for my conversion van. Itll be a decent test at 7000 lbs.....and maybe 800 hp.
The Silverado SS TC will take more than 1000hp easily. There have been several trucks in that range with N2O, Procharger and twin turbos without issues. The only break I've heard of was someone snapping the internal chain trying to dyno it with the front shaft pulled.
  #44
ss454327's Avatar
Also try Silveradoss.com
Old Jan 13, 2017 | 02:22 PM
  #45
TrendSetter's Avatar
np3 is the np149 transfer case which is a viscous coupler style one. the nr3 is the borg warner awd case. the np149 is the more desireable one for performance. i doubt they are interchangable without replacing driveshafts
http://www.fullsizechevy.com/forum/f...-how-it-works=
Old Mar 27, 2017 | 03:06 PM
  #46
Grendel's Avatar
Interesting thread. I have F+R 2006 Corvette suspension, a built LS2, a built 4l65E and a TBSS transfer case... thinking an aluminum frame and a front differential with a 5th gen Camaro rear to go along with a 34 Chevy body I have kicking around. I want to do "bigs and littles" as I have a set of 21/20" Forgelines off my Vette. Light weight, AWD with 560ish hp built to rev should be a lot of fun with paddle shifters and good brakes.
Old Jun 27, 2017 | 11:21 PM
  #47
awd69camaro's Avatar
Originally Posted by TT402LS1
This might sound really out there, but.......Anyone ever done an AWD conversion on a non AWD vehicle? I understand their would be alot of fab work (67 Chevelle) but it would really help hooking the car up. (DR's all the way around) I was thinking S10 box and acle up front. Can these be modified to handle the power of my TT402??
Any info would be apprecited! Thanks!!
I am building a awd 1969 camaro as we speak!! check out my progress
Attached Thumbnails AWD Conversion???-front-camaro-view.jpg   AWD Conversion???-bully-racing.jpg   AWD Conversion???-transfer-case-view.jpg   AWD Conversion???-unnamed.jpg
Old Jun 28, 2017 | 10:52 AM
  #48
tokuzumi's Avatar
There's a guy on this forum doing an AWD build of a 67 Cougar. Hasn't had any updates in quite a while, though. I think he sourced the engine/driveline stuff from a Buick Rendezvous, or Rainier (whichever one was the Trailblazer clone).
edit: https://ls1tech.com/forums/conversio...onversion.html
