Ls1 dodge ram!!!
Old Nov 22, 2012 | 05:17 AM
  #201
silverz28camaro's Avatar
Another before/after of the steel aluminum unit, IMO the aluminum looks alot nicer ans is up to the task of a beating I gave it after the install
Old Nov 22, 2012 | 05:18 AM
  #202
Old Dec 24, 2012 | 12:12 AM
  #203
Old Dec 24, 2012 | 12:24 AM
  #204
97camaroguy's Avatar
Originally Posted by silverz28camaro
'murica!
Old Dec 24, 2012 | 12:27 AM
  #205
Originally Posted by 97camaroguy
'murica!
Old Jan 24, 2013 | 12:23 AM
  #206
Found this truck on youtube
Old Mar 8, 2013 | 09:32 AM
  #207
Tipnitty's Avatar
Alright, I found the thread man. Was nice to meet you yesterday and see the cars man.
Old Mar 20, 2013 | 12:53 AM
  #208
Its been over 6 years since the 4wd has been operational, time to get it going and see what it does
I got this bone yard axle from a buddy, its the same axle and I thought it would be worth buying since I daily my truck and this would let me slowly build it up
Old Mar 20, 2013 | 12:56 AM
  #209
I decided to weld all the areas that act as sleeves and from the axle to the differential housing. set up some matching 3.90s , and gave it an epoxy paint job
Old Mar 20, 2013 | 12:57 AM
  #210
Old Mar 20, 2013 | 12:58 AM
  #211
Stayed late at work and swapped out the old and in with the new
Old Mar 20, 2013 | 01:00 AM
  #212
I did my axle, and my co-workers worked on their projects as well, GTO was getting ported 5.3 heads and tv2 cam, and the 99 cobra was getting new big nitrous solenoids and purge/stand alone fuel cell.. we were all up til 230 am last sat night getting these cars/truck finished up
Old Mar 20, 2013 | 01:02 AM
  #213
Old Mar 20, 2013 | 01:03 AM
  #214
Sadly enough still no 4WD I need a special 7290 to 1330(bigger yoke on axle) u-joint that I just ordered tonight, should be here next week and then it should have 4wd...finally
Old Mar 20, 2013 | 01:05 AM
  #215
The dodge style strap yoke is weak, I broke a few with the 318 on 4wd launched, I found a 1330 yoke with the much bigger U-bolts and thats why I need the conversion joint
Old Mar 20, 2013 | 05:48 AM
  #216
Checkmate's Avatar
Looks good. Will you have add or change any wiring to make 4wd operational
Old Mar 20, 2013 | 08:30 PM
  #217
No additional wiring required, the transfer case is engaged by a switch
Old Apr 22, 2013 | 06:31 AM
  #218
Checkmate's Avatar
What are you going to do for a vss from the transfer case to keep the PCM happy when in 4wd
Old Apr 23, 2013 | 11:50 PM
  #219
When I', in 4hi the computer is fine, I can shift to 4 lo and that throws off my shift points...I really don't need 4 low, but even if I did use it I can manually shift it 1st 2nd, anything faster then that and I may as well be in 4 hi...but just in case I need to pull a stump out...4lo + 3600 stall is mean
Old Apr 25, 2013 | 10:09 AM
  #220
Checkmate's Avatar
I thought about it more after I made the post and realized you didn't need to do anything.
The 360 blew up in my ramcharger so looks like I need to get the rest of my **** together and make this swap happen.
