mounting TV cable on ls carb intake
Old Apr 21, 2010 | 08:37 PM
IHEARTLS1's Avatar
Default mounting TV cable on ls carb intake
i have a 2004R, which requires the use of a tv cable. i had it set up with a bracket for my sbc, but now i cant find a convienient spot to mount the cable with my carbureted LS engine. does anyone have any pictures of how theirs is hooked up?
Old Apr 22, 2010 | 03:01 AM
LS1MCSS's Avatar
What part can you not find a spot to mount? I can take pictures of my setup, but it would be Sunday before I have time.
Old Apr 22, 2010 | 06:23 AM
1970camaroRS's Avatar
I use this from Holley:
http://www.summitracing.com/parts/HLY-20-112/
Old Apr 22, 2010 | 06:59 AM
TomM's Avatar
Try this...call them, they may just sell you the base plate and bracket. I used it on my 700...worked great..
T,
http://www.bowtieoverdrives.com/cata...php?ITEMID=213
Old Apr 22, 2010 | 05:46 PM
IHEARTLS1's Avatar
i need a spot for the big potion of it to sit still. im not spending 100 dollars on a bracket. the older setup i had bolted to the two middle intake bolts on my sbc.
Old Apr 22, 2010 | 08:05 PM
S10xGN's Avatar
Heart,
I used Lokar stuff on my setup:
Old Apr 23, 2010 | 12:09 AM
IHEARTLS1's Avatar
thanks for the picture. i have the standard factory TV cable, and i need to find a good way to mount it as is. the only way i can see doing it is off of the carb this time considering the intake is not providing me with any place to secure the bracket to.
Old Apr 23, 2010 | 04:04 AM
LS1MCSS's Avatar
Use these and your problem is solved. That second one is really too expensive, but you can most likely find it cheaper. I have a source to get them for about $30, if you need one.
http://www.summitracing.com/parts/HLY-20-44/
