Mustang K Members: AJE vs the rest
LS3 into an 03 Cobra, what are the pros and cons of the AJE swap K member vs other tubular K members and using the 4.6 mounts?
Someone told me I cant remove the trans in the car unless I have the AJE K Member because the AJE moves the entire assembly forward, not sure that I will need to but in the event something fails I'm not looking forward to an engine/trans pull.
I live about 15 min. from AJE and have a good friend that has been there a long time. They are from my experience by far the best choice for your swap. You are correct about it moving the engine forward. I can ask him any questions you would need to know!
Is it aluminum or iron block? The extra motor mount holes on the alu motor will make a difference. If you don't want to cut, weld, and modify, just get the aje setup.
If you're local to Miami I can bring the mockup motor out =)
I talked with him tonight. He said the bellhousing will be in the same spot as the factory tranny and will be able to remove it without problems. He has a scratched display model he would sell really cheap. PM me if you want his number
2006, 46, aje, difference, factory, gto, kmember, kmembers, kmembers2006, mar, measurements, member, members, mustang, mustangmember
