Bosch Relay Connectors, Looking For Large Wire Versions...
Wiring up the usual double electric fan set-up. Am using the usual 30 amp Bosch relays. All the Bosch relay connectors I find, have really small gauge wires coming out of them. Anyone know where to buy connectors, with pigtail wires coming out of them, with larger gauge wires? I believe the fans call for a 10 gauge supply wire, for instance. Thanks for any help on this.
I bought a 4 relay housing that came with the relay spade connectors without wires connected. I know I crimped 12 g. wires on it and 10 g should fit too.
Painless and a few other companies make them.
Look at Waytekwire, they should have the sockets and the crimp connectors
They also have some nice 70 relays with the 3/8" wide terminals on them, the only thing wrong with those is they don't come in SPDT, so you can't wire your fans for Series / Parellel using them
The junkyard is your friend here.
I pulled a (3) relay setup with a 50 amp fusible link (probably 70 amp working load ???) out of a Toyota Corolla. Re-pinned the connections and molded into my existing setup. Waterproof, factory looking integration but is rewired to work the factory setup and it works "fan"tastic.
I think I paid $5 for it. It looks great too.
I used the 4 gang relay box from Haywire, Inc. The block comes with relays, cover, and pins; their catalog photo shows it with wires (?). Nevertheless you can crimp whatever wire you need. Here's a photo of my fan relay setup; the 4th relay is for the fuel pump.
Andy1
Andy1
http://www.pcsconnectors.com/bosch_relays.aspx
they have blank crimp connectors also. I find it much cleaner to repin the wires than using pigtails.
http://www.pcsconnectors.com/delphi_terminals.aspx
a couple of other options
http://www.repairconnector.com/categ...-AND-PIGTAILS/
http://www.texasindustrialelectric.com/relays.asp
JY for mine. Late 90's 3.8L minivans have the good oval relays and 3 large ga sockets per center (5 relays). Plenty enough for an IGN and dual fan setup
New kits require a terminal specific to the relay socket. Check out mouser.com for what you need. There's a bazillion different terminls
I have used this place, excellent prices but you have to order $20
http://terminalsupplyco.com/Relays.aspx
