new caddialac blown motor will it fit a F-body
i may be wrong, but i assume your talking about the lsa, and if so, im pretty sure that its basically an ls3 with a supercharger, so it should fit, but there may be clearance issues becuase the supercharger is all on the top, intercooler included i believe
I agree with everything so far. that blower will work on any gen4 engine (rectangular intake ports on the heads), so if you swapped an engine in with the blower yes (or had your ls1 punched out to take rec. port heads which usually have valves too big for 346s). The blower itself is smaller than, say a maggie, or a kenne bell and some of those have variants that require minimal cowl trimming..
just my toochentz
just my toochentz
planning a LQ4 or LY6
I was actualley planning a LQ4 or LY6 (since they are low compression motors and the L92 heads would fit) w/ this Caddie. blower.
I would also want to alter the pulleys for more than stock boost.
also would a 216-224-551-551-115 blower cam (designed for the 346CI) be to small for the LQ4 or LY6?
maybe a 222-228-551-551-15 would be better for a larger than 346CI
the procharger is nice however it's pricie and requires maintaince (oil changes)
Thanks for advice
Thanks for advice
Or you can buy some small-bore rectangular heads from Mast Motorsports.... but they're pricey. Another aftermarket shop sells them too... RLP or something like that?
just my toochentz
just my toochentz
427ci
looks like a 427CI w/ dry sump oil sys.
did the cowl have to trimmed like w/ a Maggie blower?
can solid motor mounts be cut and made shorter?
also if I had the Caddie motor, trans. and PCM would the TA guage cluster still work?
Thanks
yea, working on this stuff at the OE level is a completely different world than the aftermarket, too bad not all of us get to work on such "fun" projects at work. But its still a pretty cool place to work.
