BRP Conversion Kit Updates
Old Sep 28, 2010 | 10:05 AM
BRPhotrods's Avatar
Default BRP Conversion Kit Updates
We've been busy designing the new 62-67 Chevy 2 kit, but we've also been going through and updating our other kits. We recently discovered some fitment issues with our 68-72 A-Body conversion kits, so we brought a few cars into the shop last week and re-designed that kit. Our kit now uses the Cadillac CTS-V oil pan which sits flush with the bottom of the cross-member. The engine & frame mounts bolt in to existing holes in the frame. The cylinder head clears the a/c box by .250" at its closest point and the 2" headers clear the frame with .250" clearance also. The low mount F-Body accessories clear the frame & steering box, but you'll need to modify the a/c lines. One of the cars we used for fitment was a 1970 El Camino, which gave us a chance to re-bend the humps on our cross-member to make sure it clears the floor. We have manufactured 10 kits and they are heading to the coater this week. I apologize for anyone that has had issues with our previous A-Body kits and if you would like to swap the parts out please call or PM me. I do my best to return any missed calls and PMs, please give me enough time to do so.
Another issue we addressed was the headers for the G-Body cars, the driver’s side header interfered with the shifter linkage. We brought a Monte Carlo SS over to Hedman/Husler and they re-designed the driver’s side header to give adequate clearance for the shifter linkage. If anyone is dealing with this problem on their G-Body please call or PM me.
Jeff
BRP Hot Rods
770-751-0687
Attached Thumbnails BRP Conversion Kit Updates-img_0103.jpg   BRP Conversion Kit Updates-img_0134.jpg
Old Sep 28, 2010 | 10:59 AM
wtf.suv's Avatar
any update or time frame on the chevy II conversion?
Old Sep 28, 2010 | 12:00 PM
BRPhotrods's Avatar
we're waiting on the frame plates. Should be next week, but I'll be leaving for LSx Shootout on Thursday so I might not get back on it until I get back from that.
Jeff
Old Sep 28, 2010 | 08:47 PM
hs70ss's Avatar
I already have edelbrock headers would you know how your kit works with them.
Old Sep 29, 2010 | 08:16 AM
BRPhotrods's Avatar
Not off hand, we have never tried them with our kit. If you are near-by your welcome to stop by and we can try them in the mock-up car.
Old Sep 29, 2010 | 08:26 AM
BRPhotrods's Avatar
Thanks for the all the input on our kits! Please keep us informed of any ways we can improve our products and thanks for the praise we've recieved as well. We've been spending the last year (when I started here) trying to figure out what problems we have, how to fix them and how to correct them with our customers. Thank you for supporting our products and helping us grow as a company.
Old Sep 29, 2010 | 10:16 AM
hs70ss's Avatar
Jeff
When are you going to be there. Wouldn't want to bring a kit with you for a 70 chevelle. Is the pricing still the same as on the website.
Old Sep 29, 2010 | 11:00 AM
BRPhotrods's Avatar
We'll be there for the entire show. Give me a call and I can bring you a kit, we are already bringing a few for other people.
Jeff
Old Sep 29, 2010 | 11:40 AM
hs70ss's Avatar
Which a/c compressor do you recommend using.
Old Sep 29, 2010 | 01:21 PM
BRPhotrods's Avatar
We used an F-Body compressor for mock-up, everythign clears. The only thing you might have to do is modify the lines that go into the compressor.
Old Oct 3, 2010 | 10:36 AM
2Aspire's Avatar
Jeff
BRP Hot Rods
770-751-0687
Does this address column shift interference? I see that your mounts raise the CTS-V pan to a point where its flush with the crossmsmber.
I used John Bs mounts that Put the CTS-V pan about a 1/2 below the crossmember and I have seen a few use your headers for G-body that fit but had the console shift not column.
Old Oct 4, 2010 | 08:22 AM
BRPhotrods's Avatar
No, we didn't build it for use with the crossshaft, it won't clear the headers and the selector shaft sits back about 3/4" from the factory location. It can be done, but you'd need to fabricate a cross shaft with hump in it like the one I built for my truck, and you'd need to move the bracket back on the frame and lengthen the shaft.
Old Oct 7, 2010 | 09:15 PM
byrons1502's Avatar
My install seems a little tight on a/c box. Trying to install stock 5.3 truck motor before i put it in a 89 truck.
Old Oct 13, 2010 | 10:52 PM
wtf.suv's Avatar
any updates on the chevy II kit? i could use a set of headers like yesterday!
Old Oct 14, 2010 | 08:29 AM
BRPhotrods's Avatar
I just posted a couple of pics from my phone of the mock-up work in the Chevy 2 thread.
Jeff
Old Oct 14, 2010 | 08:31 AM
BRPhotrods's Avatar
Are you installing it int he 89 truck and it's tight?
Jeff
Old Oct 14, 2010 | 10:47 PM
70cartruck's Avatar
using your mounts on my car.....they are the original design....was going to try and drill holes on the cross member because of fitment issues with my h3 oil pan...instead i just took your measurements...bolted the mounts to the engine...sat it in place and burned them in where it was square on the crossmemeber....works great....thanks for all the help
Old Oct 15, 2010 | 09:07 PM
byrons1502's Avatar
Sorry for the confusion. I installed the engine in a 69 chevelle and it hits the a/c box. I removed the box to see how close it would be. I took pictures and could not get them to load. I was mocking up the chevelle with the engine before i installed it in the truck. Mock up is taking longer than i thought.
Old Oct 18, 2010 | 08:26 AM
BRPhotrods's Avatar
The 68-72 A- Body kit was one of the kits we've re-designed, the engine was sitting back too far and hitting the a/c (exactly what you ran into). Now the kit clears the a/c box, it also now uses the CTS-V oil pan which sits flush with the bottoom of the k-member. Give me a call or send me a PM with your information and I'll get the frame mounts and engine mounts swapped out for you.
Old Oct 18, 2010 | 09:11 AM
Jones'n's Avatar
When will the in-frame S-10 long tubes be available for sale?
