78 Datsun 280z-------------> 5.3 Build
#181
GREAT.
The tokico Illumina shocks i ordered to complete my coilover setup are on national backorder - or thats the line i was fed by an ebay seller.
I ordered them the 4th, and they FINALLY had the courtesy to tell me they were backordered yesterday, AFTER i emailed them asking where my stuff was.
This is the SECOND company who has bent me over by not telling me they were out of a product, and selling it to me anyway! SO FRUSTRATING
On a side note, I was able to get the strut tubes prepped for sectioning ( perches removed, paint removed, etc), but the tubing cutter i bought was too small <_< , so thats as far as i got. (sorry no pics)
However, I did get my Ron Tyler diff mount done, which i had a friend waterjet cut for me. shout out to aknovaman
Tacked it while in the car
![Name: SDC10052.jpg
Size: 141.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614377d1501336246-78-datsun-280z-5-3-build-sdc10052.jpg)
![Name: SDC10055.jpg
Size: 144.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614378d1501336246-78-datsun-280z-5-3-build-sdc10055.jpg)
Idk why there was so much spatter, it was a MIG with gas. I think because the metal was so clean, more of it stuck
Also, the fuel system has been re-ordered, and should be here by the first of the week. Then it gets sent to the fab shop doing the tank, and it will be a week turnaround!
Baby steps
Baby steps
#183
UPDATE
Played hookie from work today (i work for KSU, so its completely cool). It was waaaay too nice out to pass on this day.
Here's a quick shot of the struts - yet to be sectioned
![Name: SDC10057.jpg
Size: 94.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614369d1501336246-78-datsun-280z-5-3-build-sdc10057.jpg)
While i had the diff loose for the RT mount I decided to do some cleaning and painting.
Here's the Mustache bar (after cleaning and removal of those damn bushings!!!)
![Name: SDC10058.jpg
Size: 87.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614370d1501336246-78-datsun-280z-5-3-build-sdc10058.jpg)
Diff (pre cleaning)
![Name: SDC10059.jpg
Size: 114.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614371d1501336246-78-datsun-280z-5-3-build-sdc10059.jpg)
Here's what I coated it with. Duplicolor spray on bedliner. I LOVE this shet
![Name: SDC10060.jpg
Size: 144.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614372d1501336246-78-datsun-280z-5-3-build-sdc10060.jpg)
Diff after paint
![Name: SDC10061.jpg
Size: 118.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614373d1501336246-78-datsun-280z-5-3-build-sdc10061.jpg)
and the mustache bar re-installed with poly bushings, and those two other things coated. lol
![Name: SDC10062.jpg
Size: 149.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614374d1501336246-78-datsun-280z-5-3-build-sdc10062.jpg)
#186
Thanks for the info ! Yeah, I'm using a R200 too. I just got the mustache bar for it last weekend at the junkyard for $22. I'm also going with the z31 cv axles, I just have to buy the adapters for it. There is a company out here in Cali that makes them, that way I dont have to deal with Modern Motorsports in Canada. Maybe your buddy can fab up some adapters too cheaper, IDK it would be cool though !
Your project is looking good, you'll be done before I will....Money
you know how that goes !
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#188
Did you talk to Kim to get the wheels? Gonna get a set for my new(old) Z which will be getting LS1 swapped over the next month. If you don't mind me asking what did you end up paying for them? And what size tires you plan on going with? Build is looking great though, might have to get me some of that spray on bedliner, looks like it turns out pretty good. Bet you can't wait to get that thing driving, cause I know I can't wait to get mine driving and the LS1 is still in my wrecked firebird lol.
-Will
-Will
#189
-Will
-Will
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Also have been thinking about 5 lug swapping it
#190
Spent a LONG *** time on the engine harness and body harness yesterday. To the tune of 7-8 hours. Found out that the moron who built the harness removed the high speed fan pin, so I'm currently looking for a pin to put in the PCM connector... ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Other than that, I got the plate for the relays done, and the relay section of the harness, and the gauge portion of the harness shortened. I added weatherpack connectors to connect the engine harness to my dash gauges. Also, the trigger wire for the harness relay, and the trigger wire for the starter. Basically made the harness so i can pull it in about 5 minutes, only unbolting it from the starter.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
The remainder of the fuel system should be here tomorrow, then its off to the fab shop!
slow progress....
slow progress....
#191
Thanks for the info, but the wire is ran, and the harness is wrapped up. Basically everything is its own entity now. Also worked on mounting the PCM.
Here's the PCM bracket that I built. I did some eyeball measuring, and I THINK that it will be free from interference with the glove box. If it does interfere, it is only a quick cut and weld away from fitting.
![Name: IMG_20120227_013134.jpg
Size: 64.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614315d1501336142-78-datsun-280z-5-3-build-img_20120227_013134.jpg)
This is what its replacing - as most of the factory wiring is gone now.
![Name: IMG_20120227_013211.jpg
Size: 89.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614316d1501336142-78-datsun-280z-5-3-build-img_20120227_013211.jpg)
Mounted
![Name: IMG_20120227_012637.jpg
Size: 77.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614317d1501336142-78-datsun-280z-5-3-build-img_20120227_012637.jpg)
With PCM
![Name: IMG_20120227_012608.jpg
Size: 86.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614318d1501336142-78-datsun-280z-5-3-build-img_20120227_012608.jpg)
Another fun filled day of wiring
Whew it got late!
Mounted
With PCM
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
Whew it got late!
#193
Been busy busy busy, and most of its not with the car!
Here's what I DID get done though.
Dash Mounted
![Name: SDC10071.jpg
Size: 82.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614114d1501335759-78-datsun-280z-5-3-build-sdc10071.jpg)
I had to either rebuild or notch my tranny crossmember to clear my exhaust comfortably, so i notched it.
![Name: SDC10073.jpg
Size: 90.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614115d1501335759-78-datsun-280z-5-3-build-sdc10073.jpg)
And of course filled it.
![Name: SDC10072.jpg
Size: 114.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614116d1501335759-78-datsun-280z-5-3-build-sdc10072.jpg)
Started on the exhaust - its gonna tuck up REAL nice
![Name: SDC10075.jpg
Size: 131.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614117d1501335759-78-datsun-280z-5-3-build-sdc10075.jpg)
Ran out of straight tubing - going to the muffler shop now
Dash Mounted
#197
Found them here
http://www.siliconeintakes.com/produ...f8a8f9f02dd603
Clamps are a page up.
Thanks guys! Everyone said there wasn't room for dual 3" on this car, but it's got about 3 times the room my F body did! LOL torque arm live axle for the loss.
I also am nearing completion on my coilover kit.
![Name: SDC10070.jpg
Size: 127.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/614101d1501335734-78-datsun-280z-5-3-build-sdc10070.jpg)
That in and of itself has been a huge PITA.
