how fast is a bone stock lq4 coupe? STEP INSIDE...
Old 11-22-2010, 09:58 AM
  #41
billyflantos's Avatar
Originally Posted by ZTwentyAteU
something like a 249/252 around .6teens to .620 lift on a 108+2 or +4
Only reason I say that is i;ve tried diff combos on my stock bore 6.0 and this is what I got the most out of, although my f body is 3199 w no driver in it. 4600 converter, 28/10.5, 4.86 gear(too much gear).
my cam is a cammotion custom grind 249/252 .620/.612 108+4
what kind of numbers?
Old 11-23-2010, 10:54 AM
  #42
rojs234's Avatar
Hey, billy. Hate to go off sideways again, but I have a question. Could you tell me at what RPM you cross the stripe on 1/8 mile ? Reason I ask is I'm trying to figure out a constant number to use in my formula to find speed or RPM from gear ratio and tire size. Most standard formulas don't allow enough for slippage of the convertor at speed. Are your tires 26" or 28" ? Most use a constant of 336 for manual trans, the old MOPAR PERFORMANCE used 340 for automatic. Mine seems to come out closer using 355. That figures out around 5-7%. I'm curious how much slippage a convertor like yours has. Sorry, if this sounds confusing.....just humor me Ron
Old 11-23-2010, 04:31 PM
  #43
275/60/15 mt dr's 4.10 gear and 5800 rpm thru the eigth at 100.5 mph...
Old 11-23-2010, 11:43 PM
  #44
i've got my car at tick performance having a 04 zo6 cam and springs with a oil pump installed...hopefully i should have some new #'s this weekend...i'd like to see some 6.50's@ around 102 and idle like a stocker...lol
Old 11-26-2010, 03:53 AM
  #45
topbrent's Avatar
Impressive numbers! _I had wondered what a stock lq4 6.0 would run.
Is that 2700 lbs with driver?
Have you thought much about using a much tighter lobe separation to build some cylinder pressure.
110lsa+4 or even tighter like 108 or 107.
DMMizell has commented in a few posts that the tighter 110 lobe sep. was a big part of the success of his lq4 shortblock 6.0/L92 combo.
Old 11-26-2010, 09:02 AM
  #46
52 Rat's Avatar
Billy, are you running the lq4 intake? My lq4 is an 01 model and I will be using the truck intake and a T56.
Old 11-26-2010, 11:41 AM
  #47
when i was cam only,i had a polluter cam on a 110 and yes with driver...thanks billy
Old 11-26-2010, 11:43 AM
  #48
i'm running a carbed victor jr intake with a 850 quick fuel...
Old 11-26-2010, 09:31 PM
  #49
52 Rat's Avatar
Sorry, I remember reading that. That is an excellent running 6.0!
Old 11-27-2010, 01:50 AM
  #50
ZTwentyAteU's Avatar
It dont make crap for rwhp dyno numbers, the loose converter, short gear, and 9in w/ slicks. hurt it on the dyno numbers, only 450rwhp. I swapped on drag radials and picked up 80 to the wheels, back to back runs, so it made 530 with mickey drag radials, its crazy how much power the slicks rob.
If you stuck it in a normal geared car, like a 6 speed car and with 3.42s, you are looking at more like mid 500srwhp, I assume it makes around 580-600 flywheel.
Old 11-27-2010, 04:06 PM
  #51
i meant time slips...sorry for the confusion...
Old 11-27-2010, 04:07 PM
  #52
new results with the 04 zo6 cam...1.41 60ft 6.58@103
Old 11-27-2010, 04:58 PM
  #53
topbrent's Avatar
That is awesome!
The various online bench racing calculators put that ZO6 cammed LQ4 at 470-480 hp and the equivalent of low 10:40's
http://www.wallaceracing.com/hpcalculatoreigth.php
http://www.wallaceracing.com/8th-quarter.php
Old 11-28-2010, 10:31 AM
  #54
That is awesome!
i'm going to try the qtr mile next weekend...i think it will go in the 40's hopefully....thanks billy
Old 12-04-2010, 10:03 PM
  #55
Isolde's Avatar
Should be 5000, so that's 800 rpm of converter slip. Maybe good for a PG, way too much for a 4L60E. I return any converter that can't hold 400 rpm of slip. I may be losing tenths, IDK.
Old 12-04-2010, 10:44 PM
  #56
Project GatTagO's Avatar
Received 1,460 Likes on 921 Posts
Great thread. For what its worth, I am running a stock C6 Z06 (LS7) cam in my L92. The engine is stock except for an LS3 intake, throttle body, dual valve springs, and Edelbrock headers. It put down 418RWPH through a Richmond 6spd and a 12 bolt rear.
My point is that if you go with the L97 heads down the line, I wouldn't run a crazy cam. Maybe give the LS7 cam a try.
Andrew
Old 12-05-2010, 09:05 AM
  #57
z28hustle's Avatar
Andrew
why is that?
Old 12-05-2010, 10:13 AM
  #58
Originally Posted by z28hustle
why is that?
Why what, exactly? I said a lot of things....
Andrew
Old 12-05-2010, 05:33 PM
  #59
topbrent's Avatar
Any updates?
Old 12-05-2010, 11:23 PM
  #60
Any updates?
had a rainy weekend here in nc...hopefully the weather will be good this saturday at rockingham...if anybody is in the neighborhood drop in...thanks billy
Quick Reply: how fast is a bone stock lq4 coupe? STEP INSIDE...
