e-bay grand national fuel tank and sender????
Im doing a 5.3 in my gbody cutlass .Is it best to go with a GN or a montie carlo efi fueltank and sender and just add my intank pump??And will the sender have a fuel return fitting??
Sooo all i need is the sender right??? But if im gona do it im gona do the tank and sender i just wanted to make sure i was headed in the right path....thanks for the advise .
i made a double pumper kit out of my stock na regal tank and for sure it's a tight fit even without the bucket. yes regular fuel pressure hose works fine on THE OUTSIDE OF THE TANK. plenty of horror stories of fuel line turning to black jelly on the inside of the tank. just be sure.
why not use a short piece from the tank to the rail like gm origionally did?
Oh really.......? Good to know.How does this line hold up to fuel long term? It would be ok to AN flare it then with EFI?
Get pushlok rubber hose! The aluminum hard line is a nightmare to route... ask me how i know! The pushlok hose and an ends are the way to go for ease of use and relibality they DO Not come apart without cutting the hose.
