LQ4/T56 into my 69 Camaro
Old 03-22-2011, 10:14 PM
  #481
tsnow678's Avatar
Finally modified the numbers 5 and 7 plug wires. I am using the MSD adjustable boot kit on these two. I did goof on the number 7 wire and got it a little short. Luckily I bought two kits and will have to get a replacement wire.
[IMG][/IMG]
Old 03-22-2011, 10:17 PM
  #482
tsnow678's Avatar
And now for the fun stuff. I bought this spool gun a couple of years ago and it finally got used tonight. I have never welded aluminum until tonight. It is weird welding this stuff. Its almost like soldering and not welding. I am still dialing everything in but did make some permanent welds with it. I have decided to build an aluminum frame to house the radiator and fans.
[IMG][/IMG]
Old 03-22-2011, 10:22 PM
  #483
tsnow678's Avatar
Here is the first attempt to weld aluminum. These will mount to the radiator support via bolts and will support the bottom of the radiator. I will add a cross bar to fasten the fans to once I get it in the car and get a real world measurement. I will make a removable top portion that will also tie in the fans.
[IMG][/IMG]
Old 03-22-2011, 11:13 PM
  #484
59 camaro's Avatar
damn bro must be nice, u have a lot of tools most of us dont lol, looks good
Old 03-23-2011, 01:04 AM
  #485
bmf5150's Avatar
Thats awsome!!
Old 03-23-2011, 04:06 AM
  #486
tsnow678's Avatar
The only reason I have the tools I have is I hate to pay someone to do something for me if I can do it myself. So I justify the cost of tools in what I save in labor. Or at least thats what the wifey thinks. It has been a long process getting the tools I want. When I got married 18 years ago I had one set of sockets, a few screwdrivers and plenty of duct tape.
Thanks 59 camaro and bmf5150!
Old 03-23-2011, 07:53 AM
  #487
i1aroc's Avatar
Very nice, and you can take pride in your dedication to the build. When I felt like procrastinating the next step of my build, I would check on your conversion and seeing all the work going into it, I would then get off my butt and finish the next step. Thanks man.
https://ls1tech.com/forums/chevrolet...camaro-swap.html
Old 03-23-2011, 09:14 AM
  #488
Steve68's Avatar
Need to make the welds look like you stacking dimes!!!! but it will take you a while to learn to do that, even I cant do it, but I will buy a Miller Syncrowave one day!!!
Great idea on the brackets!!
Old 03-23-2011, 09:25 AM
  #489
tsnow678's Avatar
i1aroc- You have got me off of my butt several times to get busy on the build. Steve and bmf have also been a big influence to me as well.
Steve I wish I had a TIG and the skills to weld aluminum. I think I will end up going to school and learning that process when I get a few less projects to do. My next big purchase was going to be a plasma but I think I might just go with a TIG. I passed up a TIG a few months ago, it was a Miller with the water cooled unit and all. I could have grabbed it for a deal. Being I dont know how to TIG it wasnt a great deal at the time. I can barely MIG much less TIG. The method I have is sort of crude with the spool gun but is much better than arc welding aluminum.
Old 03-23-2011, 12:29 PM
  #490
frojoe's Avatar
I couldn't agree more!!!
Old 03-23-2011, 03:04 PM
  #491
Steve68's Avatar
How can be a influance, but thank you!
I watch for the deals too but my friend own a welding co, he welds all my stuff, and says don't buy one now I'll weld all you need! but I'm looking for a deal,
Old 03-23-2011, 08:16 PM
  #492
tsnow678's Avatar
Right now we are sort of doing the same stuff and help one another. We all run into jams and sort of lean on others to help out. You will be a valuable asset once I decide to upgrade the suspension more so than now. I appreciate the hard work you put into your car and your willingness to help others. Alright enough being nice, you got that damn thing running yet **** man what are you waiting on, LOL!!!
I received the PCM mounting bracket today from Ironworks. Great quality and fast shipping! It was $30 for the bracket and $15 for shipping. If you go to their website and cant pull up the parts go to the pics section and scroll down. You will see a pic of a bracket. Click the icon and all of their parts will appear. You can email them and they will give you their address to send money through Paypal to. Simple process and friendly folk. The web address to Ironworks is: http://www.ironworksspeedandkustom.com/
[IMG][/IMG]
Old 03-23-2011, 08:50 PM
  #493
BBC632Camaro's Avatar
Nice looking bracket. Where do you plan to mount the PCM? I've been pondering this myself for mine.
Old 03-23-2011, 09:06 PM
  #494
tsnow678's Avatar
I am going to see where the factory harness allows and go from there. If it will reach the passenger fenderwell it will go there. If not it may go on the firewall as far away from the headers as possible. I am trying to avoid cutting and splicing X number of wires if at all possible. I will keep you informed on what I find out. If you get to that point first let me know.
Old 03-23-2011, 09:38 PM
  #495
bmf5150's Avatar
Nice bracket,I made one for my PCM at work tonight!
Old 03-24-2011, 08:38 PM
  #496
tsnow678's Avatar
Nice bracket you built! I was thinking about sending mine to one of our vendors and have it plated. I need to see what the cost will be before that happens. I may do that or powder coat it. Then again a rattle can has its name all over it if the two other options are not cost effective.
I finally got a belt to fit after the third attempt. I brought my old belt in with vice grips attached and we measured it 10 times and agreed on a 73 3/8" belt. Well that would even come close. Ended up going with a 75" belt that fits perfect. My indicator on the tensioner is on the correct line for a new belt. I did find out an easier way of installing the belt. Put it on everything but the water pump and then pull the tensioner and slide it right on. Since the water pump pulley is smooth it slides right on without having the belt in the way while trying to move the tensioner.
Old 03-24-2011, 08:46 PM
  #497
futureuser's Avatar
You're closer to driving than me! After watching you make those brackets, I think I'm going to run my existing radiator for a while. 'looking good.
Old 03-24-2011, 09:47 PM
  #498
bmf5150's Avatar
Yeah I'm going to rattle can my PCM bracket,just want to match it to rest of the engine compartment!!
Old 03-24-2011, 09:58 PM
  #499
tsnow678's Avatar
I figure if its good enough for BMF5150 its good enough for me!
Old 03-25-2011, 08:04 AM
  #500
Steve68's Avatar
nice bracket, I need to get mine in some primer,
Quick Reply: LQ4/T56 into my 69 Camaro
