Stans 1968 camaro LS swap and other upgrades!
#401
Nice pool, I have a cheap Intex 3X15 for the kids I get in it too, the new house has a small inground, right now its green, I'm hoping to close in 45 days and get started on the 40x40 or bigger shop, go tthe sub in the garage I've bolted some stuff to, going to drop the older kid off and then I'll post some pics!!
#404
So far I really like the ls in the Camaro,I still have a few small bugs to work out and I really haven't taken it much farther than my subdivision!need to take it for a good ride and test it out!!!!the 3rd gen steering box made a nice difference to the steering!!!I still have a little play in my steering just like it had with the old steering box!I really wonder if it's the steering shaft?something I need to figure out!!I need to road test it better so I can drive it two hours away to get it proper dyno tuned by Jesse bub of wait for me performance!he charges $250,can't beat that!!!also the old manual brakes have to go!!!!
#405
Need some advice guys,I have a weird problem !after my car seems to warm to say around 190 degrees if I go to turn the car off and re try to start it , it doesn't want to re start !like the starter can barely turn the motor over ??I have the fans running at that point,but even if I turn off I get the same results!I thought I was happening do to too much draw from battery when fans are running but that's not it?? Battery seems to be charged fine !if I let it cool off some it will re start!
#406
Do your headers run close to the starter? Maybe you are heat soaking the starter. You can wrap the starter with a heat barrier. I know they make a one piece wrap that will fit most starters. Just a thought. Do your headlights burn bright when this situation occurs? If the battery was in question I would try to cut the headlights on when cold and then when this problem arises to see if there is any change in their brightness. If there is no change there I would suspect the starter.
#411
That tuner is cheap. Bring your camera!
#412
You would think if it was getting that hot though the wire loom would have done turned colors and started to melt away. Whats the possibilties of a bad starter? I know the old SBC starters were bad about the solenoid hanging causing the same issue but yours is a gear reducted stater and shouldnt have this issue. I had a starter that struggled so I assumed it was a bad connection, battery, ground etc.etc. turns out it was the starter itself.
#414
The idler arms on the chevys were terrible about premature wear. That would cause the loss motion. I would only use MOOG products what ever part is worn. What about the box itself? You can adjust the freeplay on the pinion and the side load. Is the shaft deflecting at the joint?
#419
Well I think I figured it out,it was ground issue!re did them all!!!I have battery going to block,block going to frame!also a strap on the head going to frame!I also put a ground going from battery in the trunk to the frame in the trunk!so far It us working!!!thanks for the advice guys!!!
