Stans 1968 camaro LS swap and other upgrades!
Old 03-17-2012, 01:53 AM
  #581
bmf5150's Avatar
Got a question for u guys,my new Holley dominator efi does not have a plug for the alternator,so I need to figure out which pins of the plug I need to send 12v to get it to work! My alternator is from a 1997 corvette!
Old 03-19-2012, 03:56 PM
  #582
game-over's Avatar
HEY.... question for you.... what angle is on you engine tranny drive shaft... im getting different stories on where it should be..
some say 0-1 degree which causes you to cut your tunnel..
some say 3-5 degree which is the stock 1st gen angle
both say it will cause a vibration... what are you using.....
and did you have to cut your tunnel
and do you get any vibration above 70 mph.
Old 03-19-2012, 04:10 PM
  #583
bmf5150's Avatar
I put all 4 wheel on jack stands close as level to how car sits on street!i then set it at 4 degrees,have had no issues!
Old 03-19-2012, 04:16 PM
  #584
game-over's Avatar
thank you... im just worried after hearing that.. lol
because i do plan on taking it hi up in the mph racing and such... i would hate to get done and have done it wrong
Old 03-19-2012, 04:23 PM
  #585
bczee's Avatar
This engine angle subject has been talked about over and over.. Rear Pinion angle is part of what you need to know and set the Engine angle to. Just setting the Engine angle to 2-4 degree might not be the best thing.. but it usually is in the Ball Park as far as where to start.
Suggest you research "setting engine and rear pinion angle" both here on the forum and Google'ing it. Unless you are building on a Steel platform designed for building cars.. too mary variables will come into play once the car is completely build and road ready that will might possibly change the level and angles of the car/engine/trans and rear pinio/drive shaft angles.
BC
Old 03-19-2012, 04:30 PM
  #586
bmf5150's Avatar
Game over,I am a novice so I listen to what mark from street and performance suggested to me!
Old 03-19-2012, 06:43 PM
  #587
tsnow678's Avatar
Did you get your answer? If not there is or was a wire(i think brown) that used to run to your external voltage regulator that you can use to turn on the alternator. If not you will need a wire that is hot (key on only). I wouldnt worry if its hot during startup. Now to find out what the pinout is of your alternator. If I read correctly its #15 in your red connector, circuit number 225 and it should be red in color. Do you have a red wire in the factory alternator plug? If so that should be the only wire it takes to cut the alternator on.
Old 03-19-2012, 08:46 PM
  #588
bmf5150's Avatar
Mark at street and performance told me
Alternator
D-12 v post on back of alternator.
C-12v key on power source!
Then another forum member told mePin D is voltage sense usually goes to battery.
Pin C is field control goes to PCM so PCM can control alt output. (C2/11)
Pin B is lamp control. On stock setup is goes to PCM (C2/77)
If you're running it non-PCM controlled can just use pin B to the lamp. If not using a lamp put a resistor inline to switched +12; 560 ohm 1/2 watt will do the trick.
Old 03-20-2012, 01:57 AM
  #589
bmf5150's Avatar
Well guys I got a new toy for the camaro!!!!
Kenne Bell 2.8L “H” Big Bore blower with both stock Corvette (ported though) and Camaro Mammoth. NIck williams polished 90mm and 102mm DBW throttle bodies. Lower and upper manifolds with intercooler.
LFE 2003 Cobra heat exchanger, Bosch pump which has more capacity than what KB supplies, and a 3 gallon Jaz cell as well as the stock KB reservoir.
Methanol system which is a Snow Performance, Labonte controller from 6-25 psi, and a Alky control line kit.
Old 03-20-2012, 01:59 AM
  #590
bmf5150's Avatar
I bought it off of Z06psi here on the forum,he had it on his vette!
Old 03-20-2012, 02:43 AM
  #591
tsnow678's Avatar
Time to forget about everything else and focus on the Silver Bullet!!! How sweet that would be to see that blower delivered to my house!!! **** man I wouldnt go to work for a week or until I had that beast together. Tick tock you better hurry up your on a limited schedule now. Kenne Bell looks fast just sitting there!!!
Old 03-20-2012, 03:10 PM
  #592
bmf5150's Avatar
Yeah,I think I'm going to wait till fall to put on!just trying to wrap car up so I can drive for the summer!with only like 6 weeks till baby gets here and I'm super busy with my bussiness and my job I think blower will have to wait!
Old 03-20-2012, 03:15 PM
  #593
tsnow678's Avatar
I will test it out for ya? What do you think?
Old 03-20-2012, 04:07 PM
  #594
bmf5150's Avatar
;-) sure
Old 03-20-2012, 07:35 PM
  #595
c6matt's Avatar
nice.. how much boost ya gonna run?
Old 03-20-2012, 08:56 PM
  #596
bmf5150's Avatar
Thanks Matt,not sure yet!but don't want to get crazy and blow up the short block!its stock with arp rod bolts!how much boost u pushing?
Old 03-21-2012, 07:19 AM
  #597
c6matt's Avatar
on the stock longblock... 10 psi.. I've run as much as 13.5 without issues, but i backed it down for longevity.. its all in the tune... stock 2000 camaro ls1...including rod bolts...
Old 03-21-2012, 02:51 PM
  #598
bmf5150's Avatar
Well that's a big part of why I went with the Holley dominator efi,I can change pulley size for what boost I want,change my timing and let the Holley dominator self learn fuel tables!getting to a tuner or dyno around here is a bit of a drive and expensive!
Old 03-21-2012, 08:29 PM
  #599
c6matt's Avatar
even with 13psi i never touched the timing. the factory (proving ground calibration engineers) do a damn fine job with it..
Old 03-21-2012, 09:20 PM
  #600
futureuser's Avatar
This is ridiculous. I don't have any idea what you're going to do with that much power. During our 2 days of winter I was spinning at 70 with my cold drag radials and my lowly van motor. T snow's got that big ***, high comp. stoker motor so he can't handle it. I submit that I test the blower this summer, to make sure that none of that pretty silver paint gets scrathed.
Quick Reply: Stans 1968 camaro LS swap and other upgrades!
